Adjust Foglights_ How to?
Old Apr 7, 2005 | 04:05 AM
ugly_duck's Avatar
Default Adjust Foglights_ How to?
Can you adjust the Fog Lights? If so how? I'm having a problem of one shooting higher that the other. They are the stock lights.
Any help is appreciated.
__________________
Old Apr 7, 2005 | 04:24 AM
engifineer's Avatar
Default Re: adjust Foglights_ How to?
Originally Posted by ugly duck
can you adjust the fog lights? if so how? I'm having a problem of one shooting higher that the other. They are the stock lights.
I had to replace one of mine.... hope you don't have to soon... because Toyota does not offer replacements.. so it took me a week to get a price on one from the kit (Scion is working to fix this). There is an adjustment screw on them on the bottom side of the light. Take the plastic covering off of the bottom of the car ( a few screws and a handful of pushpins). Next, lay underneath and look at the back of the fog lights and you will see a round plastic piece that snaps into the housing.. there is a hole in the end of it with a Phillips screw. This adjusts the up and down alignment. I don't think there is a right,/left alignment because the light just snaps in on the sides. you will need to park it about 15-20 ft from a wall (at night or in a garage) so you can see where you are aiming them. This is the easiest way I know without aiming tools.
__________________
Old Apr 7, 2005 | 04:25 AM
engifineer's Avatar
can you adjust the foglights? if so how? im having a problem of one shooting higher that the other. They are the stock lights.
Oops, I just saw that you have an xB.... so none of that probably applies. Mine is a tC. You may want to make sure you post this stuff in the xB forums.
Old Apr 7, 2005 | 02:57 PM
ugly_duck's Avatar
ill make sure to post it in the electrical forum because it an electrical related issue. If they named the forums something easily understood not cute names it would be a lot easier to post
plus mods won't have to move everything.
Old Apr 7, 2005 | 10:09 PM
ugly_duck's Avatar
I guess i will have to use a shim to hold that sucka in the right spot.
Does anyone have a pic of it uninstalled from the rear?
There has to be a way.
__________________
Old Apr 8, 2005 | 12:04 AM
engifineer's Avatar
Just choose xB vehicle forums instead of tC
Old Apr 8, 2005 | 03:31 AM
ugly_duck's Avatar
maybe you should read the forum you are in. Where do you see this is a tC forum??
last i looked it said ICE, Electrical and Interior.
I'm sure the tC has its own forum called Scion tC.
__________________
Old Apr 8, 2005 | 03:33 AM
ugly_duck's Avatar
BTW This is in the technical section
Old Apr 8, 2005 | 03:54 AM
Max's Avatar
Max
Question... do you have factory fogs and AEM intake? If so, some people are having trouble with the left light hitting the filter. You can look and see if the back of the fog is resting on the filter. If so, its an easy fix or you can take it to the dealer.
Old Apr 8, 2005 | 04:36 AM
ugly_duck's Avatar
no aem intake, stock fogs though. I think i got it fixed. I MIGHT HAVE TO UTILIZE A SHIM or something to help it.
SloTC1
Aug 16, 2018 02:45 PM
Darrenohooligan
Sep 26, 2015 07:21 AM
StxArOne
Scion xA Aero & Exterior
Aug 21, 2015 06:44 PM
Subaru86
Jul 31, 2015 04:33 AM
Subaru86
Jul 31, 2015 04:00 AM
