brackets for wing?
besides double sided tape what brackets have you used to keep your wing on to your hatch?
i have an affections wing...kind of like a fabulous wing or the bbist wing. what bracket is used and where can i find one? thanks for any help |
Most people are only using double stick... the 3m red stuff is exceptionally strong.
This stuff is new... instead of foam impregnated with adhesive, it's a solid piece of acrylic adhesive. http://www.loctiteproducts.com/produ...d=185&plid=748 |
whatever you do, do not use the cement kind
bbist sells some clips just call them up they work great i had a hard time with just using tape to hold my carbon wing on i need more asurance it wasnt coming off
thanks guys....
Any pictures of what these clips look like??
i just got a wing too and i need to know where else i can get these clips or any other kind of substitute
Here's my 2 cents into the mix.......What I used for my bbist fab wing was regular office butterfly clips (the small ones). It held on fine and you couldn't even tell they were there. I know bbist sells the clips, but last time I spoke with him they were like $40 since they're custom made.
Very Important! If you plan on using the butterfly clips, make sure you remove the silver handles on the office cilp so it doesn't damage your car. - Andizbox* Since you bought the wing from me, I still have the office clips if you want them. Just hit me up. J |
Very Important! If you plan on using the butterfly clips, make sure you remove the silver handles on the office cilp so it doesn't damage your car. - Andizbox* Since you bought the wing from me, I still have the office clips if you want them. Just hit me up. J hmmm i think I'll take a look at this |
Very Important! If you plan on using the butterfly clips, make sure you remove the silver handles on the office cilp so it doesn't damage your car. - Andizbox* Since you bought the wing from me, I still have the office clips if you want them. Just hit me up. J All good. Glad it worked out for you. |
You still have the double sided tape on too right? Make sure you have that on as well if you're planning on keeping it on for now. This way you can have added security that the wing shouldn't fall off.
