Calling Lambo Door Guru's
Old Apr 11, 2009 | 10:26 PM
spng-bxb's Avatar
Default Calling Lambo Door Guru's
Hey all, I bought these hinges off ebay a couple months ago. The guy I got them from didn't list a brand for them, and they didn't come with the shocks. No problem right...? So I got the hinges and bought a set of M10 replacement shocks. When I got the hinge on the door won't stay up. I can manually get the door up but im not understanding it (I'm an extreme newb when it comes to these doors). SOOO I was calling on everyone with Lambo's to guide me in the right direction, even if the shocks are wrong and I need different ones (A website would be very helpful).
I really don't want any one on here "Lambo's are ___ blah blah blah!" I'm just looking for some help.
Thanks!
Hinges when I got them....
Shocks....
How "I" put it together.....
Old Apr 11, 2009 | 10:32 PM
Dkfung88's Avatar
the shocks doesnt look like its in correctly... that piece of metal is supposed to retract when its closed
Old Apr 11, 2009 | 11:18 PM
madscionce's Avatar
turn the shock around
Old Apr 12, 2009 | 12:36 AM
spng-bxb's Avatar
I tried to turn it around but the black part doesn't fit the the slot like the chrome end does.
Old Apr 12, 2009 | 03:01 AM
its_ikon's Avatar
i vote for throwing them in the trash and giving up on it. you will thank yourself later for that decision.
Old Apr 12, 2009 | 07:41 AM
ivanbBpr's Avatar
IT SHOULD BRING ANOTHER PART SO IT DON'T GO AL THE WAY IN
Old Apr 12, 2009 | 07:44 AM
ivanbBpr's Avatar
http://cgi.ebay.com/ebaymotors/LAMBO...Q5fAccessories
HERE IA A LINK YOU SHOULD SEE THE PART
Old Apr 12, 2009 | 08:00 AM
jamessicat25's Avatar
I vote for the most useless reply!
Old Apr 12, 2009 | 04:10 PM
its_ikon's Avatar
thank you
Old Apr 12, 2009 | 04:20 PM
chicotunner07's Avatar
from the last picture you posted, it definitely looks like the shock is just sitting there and not doing anything!
both ends have to be attatched, it must retract when the door is closed, and extended when open to acctually be able to hold the door up!
not knocking on lambo doors! i dont really care fro them, but if you were gonna get them anyways, why did you go with cheap ebay bobo kit? should have gone with a reputable company at least!
hope your door doesnt fall off causing some serious damage to your door!
Old Apr 13, 2009 | 12:20 AM
spng-bxb's Avatar
I wasn't really looking for the hinges, just came across them at a really good deal.I just figured since I do a lot of shows this would bring the "wow" factor.
I seen the piece you were talking about ivanbbpr, I'm wondering if I could find just that piece tho.
Old Apr 13, 2009 | 01:10 AM
spr0k3t's Avatar
If you have the dimensions of the piece you are needing, you might be able to get the part done up by a metal fabrication shop. Good luck and post your picks once you get everything done.
Old Apr 13, 2009 | 01:06 PM
swartzautoman's Avatar
i would agree that both ends of the shock "need" to be attached for the shock to work.
Old Apr 13, 2009 | 03:50 PM
Dkfung88's Avatar
another thing if you do plan to use those hinges..
u'll need to get some 12 gauge wires and extend the wires on your doors
Old Apr 15, 2009 | 09:09 PM
Big_Bird's Avatar
I second this motion
Old Apr 24, 2009 | 04:27 AM
rallying_the_scion's Avatar
TOCC
Default Re: Calling Lambo Door Guru's
im pretty sure hes looking for help and not saying anything about your opinion on the hinges.
but id go with a company with a more repable name. otherwise youll be worrying about foor sway and such, bearings may go out quicker and such.
but each end of the shock needs to be hard attached in order to for the shock to support the doors weight.
SuperXero
Scion tC 1G ICE & Interior
Feb 23, 2020 08:17 AM
toyotaisme
Jan 10, 2015 10:24 PM
eric_m
21
Dec 15, 2003 09:51 PM
autobotxxtonyxx
Nov 30, 2003 01:56 AM
