HID kit wont work : /
Old May 5, 2007 | 01:16 PM
biancoxb's Avatar
Default HID kit wont work : /
Ok so I purchased a set of 8000k Hids and attempted to hook them up. Only the high beams are working. Its the Bi xenon one h4 conversion, its suppose to be Plug and Play. For some weird reason they dont work. They sent me new bulbs, and they still dont go on, so its something I am doing wrong. I did not think a relay needed to be done everything seems to be totally plug and play. Any Suggestions ?
Old May 5, 2007 | 03:34 PM
burstaneurysm's Avatar
Check to make sure that you wired it correctly. What happens when you throw the high beam switch, do the highs come on? Or are the highs on when the lows are on? Try to take some pictures of your wiring, it might help a bit.
Old May 5, 2007 | 04:14 PM
snowromance's Avatar
you need a relay harness. the kit i bought said "no relay harness needed" too but i definately did.
i wanted to make my own but then i saw all the perfect matching connectors on one and said screw it and just paid the $20 for it.
its better to do it that way anyway because the HIDs suck a lot of juice when they fire up. you dont wanna risk frying your stock wiring harness, just not worth the chance.
Old May 6, 2007 | 10:21 PM
biancoxb's Avatar
ahh , im just getting the hang of doing wiring, I ust installed my halo lights to a switch today and im very proud of it haha , anyone but thanks a million for the tips, does anyone have a picture of the relay harness coming out of the ballast or wherever its wired around ?
Old May 7, 2007 | 03:28 AM
biancoxb's Avatar
this is my layout , its suppose to be simple plug and play , can someone help me out , is it missing something ?? im puzzled ah
Old May 7, 2007 | 10:09 AM
cliffud's Avatar
That's not a bi-xenon kit. you'd have to have 2 ballasts if your kit was truly a bi-xenon kit. sorry bud, might want to hit up the place you purchased this from and inquire about why there's only one ballast...
Check out my write up on how to wire HIDs here:
http://www.mobilehid.com/h4.htm - some info on there might help.
Good luck man.
Clifford
Old May 7, 2007 | 08:06 PM
biancoxb's Avatar
true , nah I was aware its not bi xenon but it comes with a standard hi beam attached to it. I just cant get the thing working still only the hi beam, thank you for the write up il give it a read up.
Old May 8, 2007 | 10:18 AM
wanachat15's Avatar
looks exactly like my kit. mine didn't come on at first too. the problem was the wiring was backwards. so when i pluged it in, yea red and black matched. but the schematics didn't. so i had to turn the pins around to red meeting black and vice versa. just recently i worked on it and wired it correctly myself. let me look at your kit a little more and see if i can figure out sumthing.
-----tom
Old May 8, 2007 | 10:25 AM
wanachat15's Avatar
checking out your thread a little more. are you sure they are bi-zenons? it looks to me like single beam. take a pic of the bulb for us. you say only the highs are working. thats the thing about HIDs on stock housings unless you have projectors, the glare will make you think your highs are on but actually thats your lows. so you might have no problems, it might just be a single beam but you think it's a bi. so like i said until you take a closer pic of the bulb. my verdict stays single beam.
who says bi zenons have to have two ballasts. some doesn't need two. only one. just when you flip the highs. a little electrical current is sent to a shield that moves up or down to control the beam. i can't find the pic i'm looking for. but here's one i found only has one balast for each sided. and keep scrolling down half way and look at the telescoping H4 bi xenon bulb in one of the square box.
http://cgi.ebay.com/ebaymotors/HID-C...09550224QQrdZ1
-----tom
Old May 8, 2007 | 03:33 PM
cliffud's Avatar
wanachat - yep, i know what you're talking about for the moving bulb kits... they have a higher chance of failure due to having a moving mechanism. here is the bixenon kit that I had in mind.
Old May 8, 2007 | 05:41 PM
biancoxb's Avatar
nah its more of a hid kit with a simple hi beam attatched to the bulb . . the manufacturer just contacted me and told me it will not function because there is no relay. Now where can i buy a plug and play relay ? thanks a million for the help though everyone.
Old May 8, 2007 | 11:44 PM
cliffud's Avatar
biancoxb - I'll send one out to you for $20 shipped. Like my kits that I sell, I'll wire it up so it's completely plug/play but since I don't have the bulbs to work on, you'll have to do some splicing.
You can order here: http://www.mobilehid.com/scionlife.htm
Thanks.
Clifford
Old May 9, 2007 | 10:00 AM
wanachat15's Avatar
glad to help eventhough it wasn't helpful.
-----tom
Old May 23, 2007 | 05:16 PM
did you get this fixed? you need a relay harness. i have the exact same setup as what you bought. once you hook it up with a relay to take the power straight from the battery to the ballast it will fire right up.
hope you got this squared away
Old May 28, 2007 | 02:21 AM
thomazwrx's Avatar
Hum wow you spent some money on those bi-xenons.
You should try getting signal from the battery its self to get rid of the "if it works" variable then you can narow it down to being your signal or the HIDs them self
clickclickw00t
Feb 18, 2015 08:57 PM
jaspercanda
Dec 28, 2014 10:09 AM
Basebllstar
Dec 17, 2014 07:30 PM
minter66
Dec 15, 2014 01:45 PM
umnitza
Dec 1, 2014 06:26 PM
