How to Clear XB Tails
Old Jul 10, 2006 | 08:42 PM
dmpsk8's Avatar
Default How to Clear XB Tails
I was just wonderin if anybody knew if the tails on the xb could have the center red lenses removed. give them the cleared out look u can get with the healights, that would be sick
Old Jul 10, 2006 | 09:37 PM
RaginCajun's Avatar
Yes the red lense does come out.
Old Jul 10, 2006 | 10:10 PM
Boxer_Rebellion's Avatar
You can remove the reflector and the lense around the brake bulb... just carefully pry them apart after baking in the oven for 5 minutes @ 250 degrees (really.) Do a search, there's several how-to's on it.
Old Jul 10, 2006 | 10:35 PM
Max's Avatar
Max
I took mine out when I candied the lenses.
Old Jul 10, 2006 | 10:39 PM
kkawana's Avatar
caution tho... pretty sure its a fed law that requires that there is a red reflector in the tail light assembly somewhere...
tho if you candie the tails red... you may be safe
Old Jul 11, 2006 | 12:12 AM
Gsnorgathon's Avatar
AFAIK, red reflectors are required on the rear of the vehicle, as opposed to merely a red color. If you candy your tails and leave the reflectors in, you're good.
If you completely clear your tails, presumably you could stay street legal by adding red reflectors elsewhere on the rear, as long as they were near the corners.
OTOH, I have no idea how frequently folks are actually cited for such things.
Old Jul 11, 2006 | 01:31 AM
brambling's Avatar
You'll have folks behind you swerving thinking they're about to have a headon collision.
Personally I would rather the tailights looked normal instead of this faddish clear stuff, but I'm too lazy to do anything about it. I'll probably get the TYC taillights someday.
Old Jul 11, 2006 | 05:14 AM
Short_Bus's Avatar
candy them with the reflectors in,,,,looks tight and legal
Old Jul 11, 2006 | 04:03 PM
brambling's Avatar
The TYC looks good with the black xB so I'm just gonna wait until I want to spend the money.
Old Jul 11, 2006 | 10:49 PM
kzhorse's Avatar
Strictly Scionized
If you take the bulb cover off you should still be legal,That is it you dont remove the reflector on the dead portion of the tail.Just dont forget to run "RED" bulbs in the top after you remove the bulb cover.
I have a question,Has anybody tried to "DYE" the lense's with Rit dye I was thinking that it midgt give you the pinkish color like the Lexus.
Scott
Old Jul 11, 2006 | 10:52 PM
RTon20s's Avatar
I haven't tried dying the actual housings, but I have tried dying the bulbs. I used a quality product from a theatrical lighting company and it still didn't last. I only did a single coat, but I don't think more coats would have mattered. In the end they went pink, then white just like the aftermarket color bulbs you can buy.
Old Jul 17, 2006 | 02:58 PM
Archngl's Avatar
I tried this. I preheated for only 10 mintues, and I only put them in for 4 minutes to be safe.
Well... I melted one of my tails. TOTALLY jacked.
So, now I'm buyin' some replacements... <---NOT HAPPY.
anywho, wouldn't it be possible to shatter them instead of sticking parts of my car into the oven?
Old Jul 18, 2006 | 04:30 PM
erodsani's Avatar
Oh no man! That sucks!!!
Old Jul 18, 2006 | 04:32 PM
Archngl's Avatar
It's not too bad. I got a new pair for 40 bux shipped off of ebay... wich means when I pull my meled buddie out to replace him, I can see if the shattering method works... if it does... well I'm goin' that route!
Old Jul 18, 2006 | 05:10 PM
kustom_play's Avatar
i plan on doing this also but im going to get a set of LED bulbs. Just get a 60 degree viewing angle and you should be fine
Old Jul 19, 2006 | 04:59 AM
peteski's Avatar
In the next few days I'll be posting a writeup of my taillight mod. It'll show how to take them apart and make them as clear as possible (legally). I did install LED bulbs as they are clear when not lit up.
I'll post it as a separate thread - look for it.
Old Jul 19, 2006 | 02:21 PM
Archngl's Avatar
I'll be waiting.
-in the shadows..
buahahahahahaha. BUAHAHAHAHAHAHA!
Old Jul 20, 2006 | 04:19 PM
Big_Kokujin's Avatar
I did mines without baking them. It took about 10 min each, and i chipped them a little, but nothing superglue couldn't fix. All you have to do is pry up the grey part along the tabs. If you aren't very careful and put too much pressure on the clear part, snap. and you will have to glue it back...
Old Jul 23, 2006 | 03:56 AM
peteski's Avatar
That looks good but I wanted to stay legal, so I left some of the red reflectors show. I hav all the pictures ready but I have to finish the writeup - almost there.
Yeah, I chipped one of mine and glued the chip back.
Peteski
Old Jul 24, 2006 | 02:32 PM
Archngl's Avatar
I chipped the living crap out of mine... but it's all inside, so You can't see it.
<---doesn't care.
And I put in Red Leds on the top so my brake light still looks clear, but shines red.
