Lambo Door How-to? (problems with fitment)
Old Jun 21, 2006 | 04:55 AM
MuNkY's Avatar
Scion Apocalypse
Default Lambo Door How-to? (problems with fitment)
So.. I ordered a kit from someone here on Scionlife, and it seems the kit doesn't fit.
Let me show you what I mean:
Top hole
Bottom Hole
Here you can see both holes.
So, did this guy send me the wrong kit? If so, does ANYONE have any idea what this kit would go on, or who its even made by?
One other question, does the Scion Lambo Kits usually come with 700lb shocks, and half inch steel brackets?
Old Jun 21, 2006 | 12:37 PM
scionmike05's Avatar
Default Lambo Doors
That's the problem unfortunately u will have to modify this kit and remember there's no such thing as bolt on! Especially on Lambo doors, of course if u spend $2500 on the right kit that's a different story.
Sorry but please keep us updated for future member with same issues.
Old Jun 22, 2006 | 02:15 AM
MuNkY's Avatar
Scion Apocalypse
Anyone else? i just have my scion in the garage all taken apart until i know if this is the right kit or not..
Old Jun 22, 2006 | 02:20 AM
oldboxman's Avatar
Just my .02 but I have seen a lot of car shows on Speed Channel and every time they have talked about a Lambo Kit they have to modify it to the car.
I don't think they make a direct bolt on kit. Good luck cause it should look awesome when done.
Old Jun 22, 2006 | 04:38 PM
RTon20s's Avatar
Do yourself a favor.
Stop the install.
Pull the "Lambo" hinges off.
Put everything back in the box.
Seal the box.
Reinstall your stock hinges and doors.
Return the "Lambo" kit.
If they won't take it back, it's ebay time.
Come back on here and thank us for saving you when you come to your senses in a few months.
Otherwise, it looks like there may be some adjustment in the upper hinge mounts. Try installing the lower bolt first and using it as a pivot point to find the correct upper mounting holes.
Old Jun 23, 2006 | 02:52 AM
I agree that's why if u want them done right it cost around $2500 at least in Miami but it's hot it's the Diablo Doors in Chrome and do an awesome job but just letting u know it will cost a pretty penny which u might fine better use elsewhere in ur ride.
It will look good but remember it can affect your sealing of the door as well.
Old Jun 23, 2006 | 03:49 AM
Short_Bus's Avatar
Rton20's makes a great point......
Old Jun 23, 2006 | 04:14 AM
Max's Avatar
Max
There is a reason they are called Lambo doors and not Scion doors.
Listen to what RTon20s said.
SuperXero
Scion tC 1G ICE & Interior
Feb 23, 2020 08:17 AM
idriveanxa
Mar 8, 2015 12:03 PM
Miqmiqmiq
Feb 4, 2015 05:05 PM
eric_m
21
Dec 15, 2003 09:51 PM
autobotxxtonyxx
Nov 30, 2003 01:56 AM
