OEM Fog Light install...
im installing factory fog lights for my xb and i can't get the relay switch off. anyone have any pointers to help me get it off? :pray:
the instuctions says to use a flathead, but i dont know how i would go about to get it off. knowing me, i'll probably break it off. |
Did you read this DIY post from the tech section?
http://overboost.com/print.asp?id=1098 |
anyone else know how to get to the relay, i dont have instructions coz i just bought em used and that link no longer works
Here's the instructions in PDF
Click here |
i got it thanks
now i found out i need a relay any suggestions? |
Originally Posted by socalscion
any suggestions?
i just emailed him thanks....but if i wanted to buy it from somewhere else and do it ghetto style where would i get one
radio shack? would i fry something trying to stick some generic one in? anyone ghetto relayed it yet? thanks alot you guys |
I heard stories that the dealers want somthing like 30 or 40 dolars just for the relay.
Re: OEM Fog Light install...
Originally Posted by ayS
im installing factory fog lights for my xb and i can't get the relay switch off. anyone have any pointers to help me get it off? The instuctions says to use a flathead, but i dont know how i would go about to get it off. knowing me, i'll probably break it off.... (later) now i found out i need a relay
This is what I did, but it was not easy because you cannot see where it needs to be plugged in, and your hand will feel like it is too big to fit and work back there while holding the plug, and it takes some contortions to get the hand in the right position to work. As I remember, it seemed logical to use the right hand, but only the left hand can make the moves required. I tried for 30 minutes using whichever wrong hand it was, before figuring that out. One tip is to use a finger tip to feel the receptacle and understand the location and orientation of the plug holes - like Braille. |
Just for my own education, what is the RELAY for? Does this have something to do with the fog lights will only turn on when the headlight is on? Thanks.
It lets you switch a high current circuit with low current on the switch side.
I picked up a relay yesterday, not oem, for $3.99.
Wally |
For future reference, the vertical prongs of the relay go at the bottom, and the horizontal prongs go at the top. I was able to do it with my right hand, but it was more of a lucky jab than any real coordinated effort. I hope that this helps! |
