Power lift hatch
Old Oct 30, 2003 | 01:59 AM
Vegasscion's Avatar
Default Power lift hatch
Does anyone know what would have to be done to have a power lift hatch so that you can open and close your rear with a remote?
Mark
Old Oct 30, 2003 | 07:11 PM
George's Avatar
Default Re: Power lift hatch
Mark
Well, that's a bit of an engineering project. You'll need two linear actuators to replace the gas springs. You'll also need a Cadillac style "pulling latch" to allow positive latching upon closure. You'll probably have to relocate the pivot points of the actuators to provide better leverage for opening.
George
Old Oct 30, 2003 | 07:43 PM
Vegasscion's Avatar
Damn all that work....it looks like im going to leave mine the way it is....I just thought it would be nice to have the back open like the new chrysler pacifica does
Mark
Old Oct 30, 2003 | 08:40 PM
BlueBox's Avatar
i think u can have it pop open (crack open) with some aftermarket motorswitch...but since our xB already has a actuator switch...unlike conventional key lock ...maybe there's a way to work that out...
someone who works for auto alarm install places should know... and i'm assuming if u can place another motor to act as a catalyst for the push open action...the trunk lid two air compressed arms can do the rest of the work and lift the tailgate?
Old Oct 30, 2003 | 11:16 PM
George's Avatar
The problem isn't opening, it is getting the door to positively close. I suppose that you could pull it shut with the actuators, but that would put a lot of stress on the hatch and you'd then have to "relax" the actuators.
I don't have much experience with air cylinders, but you'd have to have a lot of pressure to make them work in the available space.
You could do that simply by repositioning the pivots of the air springs and installing a small actuator to push the door open until the air springs take over. However, this wouldn't be able to close the door.
George
Old Oct 31, 2003 | 12:05 AM
BlueBox's Avatar
i'd be happy with the hatch's ability to open on its own... closing it would be secondary...
this would be a nice feature if the whole thing can be installed for under $150
Old Oct 31, 2003 | 12:14 AM
deathcabforme's Avatar
Maybe you get the closing system off the new 4runner. When you set it down very softly it automatically pulls it self shut. So if you put actuators on the door when it barely touched the bottom the latch would pull itself shut. Just a idea.
Old Oct 31, 2003 | 03:41 AM
mrbadass03's Avatar
Mark
George
i agree. closing = cadillac style pull-latch
l. garcia
Old Oct 31, 2003 | 05:06 AM
George's Avatar
Well, then you'd just need to install a hefty spring to pop the door open a few inches as soon as the latch is triggered. I don't know what this would do to latch life, though.
George
Old Oct 31, 2003 | 07:44 AM
WhiteToaster's Avatar
Lazy Bastards!!! :lol:
Old Oct 31, 2003 | 05:05 PM
George's Avatar
Well, I'm kind of bothered by the lack of a mechanical method of opening the hatch. It will be a pain if the electrical latch fails. I guess that Toyota saved a couple of bucks by not putting in a lock cylinder.
George
Old Oct 31, 2003 | 06:10 PM
randode's Avatar
Wagonistas
get a set of "door poppers". you know the spring loaded pins that you use with shaved doors. Put 2 of those in the door jamb, and wire the rear hatch solenoid to your alarm trunk button. then when u hit the button it will pop open a couple inches and u just have to lift it up.
Old Nov 1, 2003 | 12:57 AM
Torokun's Avatar
Try the new Sienna's rear hatch parts.
RY_TC07
Jul 18, 2017 05:18 PM
crystaljukebox_com
Feb 5, 2004 05:53 AM
