Pulling out the stock Fogs, for work
Quick question folks, before I pop under the car to check on the stock fogs, how easy/hard are they to remove and are they easy to re-attach? I've noticed some moisture in the housings and need to pull them, dump some dry rice in them and pop some new bulbs in. The originals probably have dried/loose sealing rings.
The stock fogs are pie to get in and out. They literally just pop out. Apply some pressure from behind them, and they should easily just pop right out. Do the same to get em back in. It is probably one of the easiest things to do. Luckily your not having to do it with the headlights which is a pain to remove because of the whole front end needing to be removed.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
TheTripleC
Jan 4, 2015 06:46 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
umnitza
Dec 1, 2014 06:26 PM
