Rear lip install.
Old Jun 18, 2007 | 04:21 PM
burstaneurysm's Avatar
Default Rear lip install.
I'm installing a lip on a friends box this week... I just wanted to verify that it's just the two screws in each wheel well and some 3M tape along the edge... anything else I need to worry about?
The lip has already been installed on a box, so fitment shouldn't be an issue.
Old Jun 18, 2007 | 04:24 PM
dgHotLava's Avatar
nope...more than that.
and no tape.
Old Jun 18, 2007 | 04:29 PM
dgHotLava's Avatar
if it is just the lip you are removing...
it should have 6-7 body pins from the inside going up...then it has a clip design builin to it.
https://www.scionlife.com/tech/parts...xb04_2_E01.gif
Old Jun 19, 2007 | 06:18 PM
Okay... so once the stock lip is removed, how do you recommend installing the new one?
From what I recall of the new lip, I only saw the two holes for at the wheel well. Otherwise, I didn't see any obvious mounting points.
Old Jun 19, 2007 | 06:23 PM
chipzxb's Avatar
What lip is it. Some rears mount on different than others.
Old Jun 19, 2007 | 06:30 PM
I believe it's this:
Ground dynamics VIP rear lip.
Old Jun 19, 2007 | 07:03 PM
dgHotLava's Avatar
the two holes are for the body pins...
thats it for this lip...i would go ahead and think about adding some small screws along the seam on the inside. (do this before sending it out for paint...)
Old Jun 19, 2007 | 07:10 PM
okay, and I just reuse the stock body pins?
I figured a screw or two might not be a bad idea...
It's already painted.
Old Jun 19, 2007 | 08:34 PM
dgHotLava's Avatar
it should take two pins on the outer corners.
then from under the car run some small/short screws in the seam.
as you said it has been on another box, i'll save you the fit before paint speach.
just be careful of the screws...it might crack the lip if they are too big...or they might come through the bumper if they are too long...
Old Jun 19, 2007 | 08:41 PM
Thanks for the help... one last thing...
Is it going to be easier to remove the bumper, or mount the lip with the bumper attached?
Old Jun 19, 2007 | 10:13 PM
dgHotLava's Avatar
i've never had a problem doing it wit the bumper on...
so long as you can fit under it and use tools.
Old Jun 19, 2007 | 10:22 PM
Alright... Thanks!
I'll be doing this tomorrow, so hopefully, it goes well.
Old Jun 20, 2007 | 10:33 AM
dgHotLava's Avatar
cool...let us know how it went
Old Jun 21, 2007 | 03:53 PM
Well... as I kinda expected, it fit like azz.
The lip would need a lot of work to get it to fit remotely well. I wish I had seen the previous boxes this thing was on, because it had to look just as ____ poor.
The stock lip is back on the box.
torranosaurus
Jan 28, 2015 04:53 AM
757_BRDFLY
Jan 9, 2015 12:29 PM
TheTripleC
Jan 4, 2015 06:46 PM
wesley_t
Dec 18, 2014 06:59 AM
umnitza
Dec 1, 2014 06:26 PM
