TRF xB grill
Hi guys
This grill is designed with style and performance in mind :D Stock xB grill is completely sealed. Wind cannot go through the grill. Lots of you changed to Toyota speed grill or billet grills for the sporty look and more airflow. This grill is designed to have the maximum airflow compare to most grills available now for the xB, and also give it a unique look. The white line down in center is actually part of the car. Grill insert will cover that part. http://members.aol.com/eibachmbz/trfgrill01.jpg The grill extended to the bumper. This design helps lead the wind from the bumper to the grill and enter into the center opening. The opening is just right in front of the header, which is one of high temperature part in the engine bay. http://members.aol.com/eibachmbz/trfgrill02.jpg The curve of the grill is same with the factory bumper. We design the grill to be original but also have the character of its own. This grill is designed to be mild but also sporty for xBs with or without bodykits. http://members.aol.com/eibachmbz/trfgrill03.jpg This grill is expected to be $150 unpainted and $200 painted. It will come with grill insert. As for now the material of the inserts is not decided yet, we will either use aluminum or plastic. It will be perforated with round holes instead of the diamond mesh we see on everyday Hondas. Installation for this grill is very easy. It use the stock mounting holes on each side. Double stick tape on the bottom (where the grill and bumper attached) for extra sercurity. No brain required. This grill is in production now and will be available next week. Quantity for the first batch will be very limited. I already have a waiting list for this grill. If you would like to be on the waiting list, please PM or e-mail me. I am also doing R&Ds now and see if carbon fiber is possible. Thanks |
i think it would look pretty good if you put the same grill material as the lower two grills or if you offered the lower two grills to match the top grill.
BAD ___ Hey help me Mr Sponsor.
i have a question regarding the grill...
if the outlet allows air into the engine bay... what about water? like in rain or even a car wash...wouldn't it effect the engine components? just curious... |
I actually tried to find the same grill insert design that matches the other two grills on the car... Problem is no one actually doing it...
I can find a hexagon mesh but it still not matching the bottom piece... I even tried to see if I could buy anything from Toyota and cut it to the size of the grill. This grill can be offered w/o the insert for a cheaper price if you guys want to use something other than the perforated materials :) If you are washing your car or just park outside when it rains, the purpose of the grill insert is to prevent large amount of water or unwanted object to get into the car. As long as you don't aim your hose right into the center opening, the amount of water that gets into the engine is very small. It is okay if water gets into your car, as long as it doesn't soak the alternator or battery, which in this case water will not get there. If you are driving your car and its raining, some water will get into the car passing the grill insert, but the temperature of the engine bay will vaporized the rain water without damaging to the car. Water will get into any kinds of the grill as long as there is an opening. It happened to any model car that has a grill that drags the air into the engine. However the amount of the water is very small. You are not dumping whole buckets of water on you engine in this case. We designed the grill so the bottom flat part actually have an angle to it. It tilt little upward at the inner part to prevent water gets into your engine bay when car is parked. |
Excuse me if this sounds like a stupid question..... but do you think this will help the air conditioning work better by keeping the engine bay cooler?
Sean |
Well... I have never tested if the AC can become cooler... I don't even think I am able to test it. Theoretically, if you switch the AC to drag air from outside instead of circulating in the cabin... it should be cooler, or if not air will become cooler faster. But its just all theory. I am sure it will help people with ram air intake system since cooler air flow into the engine... AC I am just not sure. |
That looks really good. One day I will be pimpin' Red Genie when I have dough to spend. :?
I can't wait to see the grill inserts & final production piece on a car. Great job!!! |
do you have any other pics like from a distance ?
[/b]I LIKE IT!!!
looks sweet....as for the painted ones, will they be availabe with factory matching colors like black cherry pearl? :wink:
I wanna see the finished product. It's looks alittle funky without a grill insert.
The painted one will be available ONLY in factory colors
I only use high quality paint from like Dupont or Toyota, and will match the factory color code. Like I said, I am still looking for the right grill insert. I will post the finishing product next week and start to sell them. If you guys interested in getting this grill, please PM me or e-mail me in advance and I can put you in the waiting list. Like I said, the quantity will be very limited from the first batch. Here is a picture from a distance http://members.aol.com/eibachmbz/trfgrill04.jpg |
KiL |
increasing the air pressure inside of the engine bay, will offset the pressure of the air flowing across the radiator.
The grill of the scion was designed in such a way to keep a high pressure flow of air across the radiator... Cooling the engine compartment does not do a fraction of the good that cooling the radiator does. So in summary.....use a grill like this that flows through, and you will essentially cause a boundary layer of non-moving air around the radiator....NOT GOOD!!! You must have high pressure outside of the engine compartment, and low pressure inside to keep air flowing through the radiator. PLEASE KEEP THIS IN MIND!!! You would be better off to make a grill that had a closed back. |
looks good...but i just wanna add my 2 cents...
i dont like where the buttom part sticks out on the bumper...i like something just a retangle with mesh grille in the middle 8) |
The grill of the scion was designed in such a way to keep a high pressure flow of air across the radiator... Cooling the engine compartment does not do a fraction of the good that cooling the radiator does. So in summary.....use a grill like this that flows through, and you will essentially cause a boundary layer of non-moving air around the radiator....NOT GOOD!!! You must have high pressure outside of the engine compartment, and low pressure inside to keep air flowing through the radiator. PLEASE KEEP THIS IN MIND!!! You would be better off to make a grill that had a closed back. Thanks! p.s.......how did you get so smart??? Sean |
