Trying to install HIDs. PLZ help.
Old May 21, 2007 | 11:06 PM
Rowdy_xB's Avatar
Default Trying to install HIDs. PLZ help.
I just got my HID kit in the mail and i cant figure out where do these plug into? Also why does one of them have 3 prongs and one has 2? Any pics/info would be much appricated.
Old May 21, 2007 | 11:07 PM
sciontc_06's Avatar
are these for an XB and what brand of HIDs did you get?
Old May 21, 2007 | 11:15 PM
Rowdy_xB's Avatar
Yes they are for the xB. They are H4s. Not sure what type of Brand they are. Heres a pic of the box.
Old May 22, 2007 | 01:22 AM
leov36's Avatar
does this kit come w ith a relay harness?, i cant tell with you pics. the question mark you got to the left, what wire is this? you need a better pic showing what it goes too. the bulb on the rigth of the pic has the prongs to plug into your passanger headlight harness, its for the hight beam. those wires coming out of the left bulb (with the blue caps on em) are to be spiced into the wires for the high beams on the driver side.
Old May 22, 2007 | 01:24 AM
leov36's Avatar
by the way, if you dont have a relay, your gonna need one. the stock xb wirring wont supply enough juice to fire up you ballast. get one from mobile hid. they can be found under sponsored sales.
Old May 22, 2007 | 04:29 AM
micaxB's Avatar
what are you talking about? i'm running mines without a relay and it's working fine.
Old May 22, 2007 | 04:43 AM
RedneckwithanxB's Avatar
they plug right into the factory plug that you pull off the factory bulb...
Old May 22, 2007 | 04:49 AM
burstaneurysm's Avatar
If you're running HID, run a harness... xenons require a huge voltage spike at startup. Over time, that voltage jump is going to fry the stock harness. Better to spend a few bucks to generate that voltage from the battery rather than drop a ton for a replacement headlight harness.
Old May 22, 2007 | 06:40 AM
cliffud's Avatar
rowdy- you ok now?
post an update and let me know if you need anymore help.
Thanks!
Clifford
Old May 22, 2007 | 10:47 AM
wanachat15's Avatar
yea those plugs just goes back from where you took the old harness out and i don't think you need a relay. i'm running mine without a relay. plug and play. but what i notice is the guys with bi-xenon is the ones running relay, not the single low beam.
-------tom
Old May 23, 2007 | 01:48 AM
Rowdy_xB's Avatar
Originally Posted by cliffud
rowdy- you ok now?
Thanks!
Clifford
Cliiford you are the man!!
I got it all figured out. Thanks again for all your help. They should be installed tomorrow, if I can get off work in time for some light outside.
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
IrjI619
Dec 21, 2014 05:04 AM
nacy333
Oct 30, 2004 02:35 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
