Better to wax before/after applying decal?
Old Mar 26, 2007 | 02:13 PM
Batmobox's Avatar
Default Better to wax before/after applying decal?
Hi all,
Just a quick question...If you are planning on adding a decal and also waxing your car, which should come first?
Thanks!
Old Mar 26, 2007 | 02:26 PM
vintage42's Avatar
When applying sheet vinyl like 3M film or graphics for permanence, the instructions say to clean off wax using a 70% alcohol solution (which is how it comes in the drugstore bottles). I don't know what happens if you don't clean off the wax. Maybe the decal will remove easier, hopefully not before you want it to come off.
Old Mar 26, 2007 | 04:27 PM
krustytheclown's Avatar
If you don't remove any dirt/waxes before you apply the decal, the adhesive won't adhere properly, causing it to peel off easily.
Old Mar 26, 2007 | 04:30 PM
guitarguru44's Avatar
yup, you want the surface as clean as possible to promote adhesion...
and watch out for waxing decals. Most will not have a problem but some might discolor..
Old Mar 26, 2007 | 04:44 PM
Batmobox's Avatar
That's what I thought, but I just wasn't sure if it would make the wax job look enough. Thanks guys!
Old Mar 26, 2007 | 07:25 PM
TerribleTed's Avatar
Professional grease and wax remover pre paint solvent is the best to use. PPG Brand product DX 440 is particularly good. Check out your nearby Auto Body Supply. You might have to but a gallon but it is not very expensive and can be used for any grease, glue, gum etc removal as well as for removing porr quality paints (spray paint over spray etc). It will generally not effect surface properly painted with automotvie paints (if there is any question check on a spot that can not be seen to ensure it does not effect the paint).
StxArOne
Scion xA Aero & Exterior
Apr 3, 2018 02:22 PM
edwinisdumb15
Regional - Pacific South
Sep 13, 2015 12:44 AM
10spokess
Aug 16, 2015 02:50 AM
Subaru86
Scion FR-S ICE & Interior
Aug 12, 2015 12:26 AM
mc1114
Scion tC 1G Aero & Exterior
Aug 10, 2015 10:34 AM
