Door Locks and Dome light Dont work -help?
Leaving work one night my car alarm went crazy on me - it would arm itself just after starting the car and then would not shut off (!) when i took the key out (its never done this in 2+ years) so i stalled it (stick shift) and then the anti-theft start-kill relay kicked in, would not shut off from arming/disarming the vehicle so i reached up and unpluged the brain, problem solved and i drove home.
I did a factory reset on the brain and everything was dandy - until this morning. I go out and notice the dome light is not working, no big deal right? just a blown bulb, right? wrong. The door locks do not work. period. They don't arm, disarm with my remote, driver and passenger lock controls and the factory key less entry does not work aswell. My alarm is back to normal and now it beeps to indicate to me that its not sensing the door locks properly.
I have checked and rechecked all stock fuses with a ohm meter in the location under the dash and under the hood. This alarm has worked for 2 + years fine and now this.
Also the on dash door "open" light does come off and on with the doors opening and closing, is this the possible Door lock Control relay issue? If anyone has any input it would be much appreciated. Thank you
I must add to that the dome light only works in the "on" position. Off is "off" and the door position is also "off" - with doors open and no its not a sticky door switch ive tried to open all 4 doors and nothing and i cant access the trunk hatch either
VCUBoy714
Scion tC 1G ICE & Interior
01-05-2015 08:46 PM
