door paint question?
while my brother was waxing his BSP xb i noticed that the pillars and tops of the doors are painted the same color as the rest of his box. why is the BSP the only color that this is this way? on mine, these areas are a flat black. i'd love it if they were the same color.
I don't know. If you have one, just go out and check. It's easy to tell the difference between vinyl and paint and if there is vinyl it should have paint underneath since the whole car is painted before that is applied. I would suggest finding an inconspicuous spot to do a test peel from just in case.
Thanks for nothing!
j/k
ya i have one, ill check it out after work, but im pretty sure that it is not a vinyl because of the way the doors "connect" with the windows, but ill let you know tomorrow
Originally Posted by chadfo
I found one in the gallery.
their is a tech thread on here too but i wouldnt use a heat source. i pulled and peeled. took me about an hour in 65 degree dry weather
https://www.scionlife.com/forums/viewtopic.php?t=3955
Hey Guys! That is my car up there....
The process took me about 45 hour for the one side and about 30 for the other. Once you get the hang of it, the process is really easy.
And Yes, every scion (xa,xb,tc) has the black tape not including black cars.
If you have any questions let me know.
