Factory alarm help rs3.0 need to remove for new alarm
I installed remote start into a new rs 3.0 and found out the factory alarms goes off when armed and remote start is in gauged with new alarm i did use factory disarm for new alarm to disarm factory alarm all that works great is just when i remote start when armed the factory alarm goes off. If anyone has a quick fix that would be great.
the new alarm is a dei matrix 3.5 rs
goodness...I'd love an answer to this myself...
I have the same issue, the shop that installed the alarm simply said after 2 times taking it back that the factory alarm -can't- be disabled.
I hope this reply didn't get your hopes up...or did you get it figured out?
Alarm
well i did it reoved the problem and its really easy there is a plug that is in the steering wheel area and this need to be bypassed this is a plug that was added for the factory alarm ill try to getsom pcs up for this.
yeap thats the way to take out hte factory alarm
simply get down the stering box take the cover off
unplug two plugs and the the alarm is out that easy
simply replug the other twwo plugs that whats left without conection
and thats it the hole allarm is out with the module the two relays
and the motion sensor
Re: Alarm
I think if the explanation is simple enough I can figure it out myself without dealing with this shop again.
Well since the guys that installed our viper remote start could not disable the factory alarm, every time we started the car with the doors locked the viper alarm would go off, if we unlocked the car then started it and relocked it with the viper remote all was fine.
All my husband did was unplug the power from the factory alarm, see the pic below, remove the glove box and its on the RIGHT side on bolted to the body of the vehicle.
Does this look right to you? I think he knew what to look for based on your reply but the steering wheel area in my car is just the cruise control stuff. My husband takes the most blurry pics so apologies if you can't tell???
i got it!!!!!!!!! thanksss
okay if you look the picture there are some loose cables those are from the plug your husband took out .I used the same led of the factory alarm.So the would thing that is factory
it's a MESS. My husband found the book on installing the factory alarm.
I am installing a zenesis remote start 2 way paging system in my xB and want to make sure I dont make the same mistake.
Pictures are not showing up very well is it possible for you to post them or the links and give more detail?
no way if you do that you will have a lot and i mean aLOT!!!! of trouble
if you want your box to get crazy jajajajaj do it
no what happens is that went you actived youa after market alarm your factory alarm
will aslo trigger and so on your better off deciding if you want the factory one or
the after market one.(the after market is way better than the stock)
Ok so I will get rid of my stock key flob and everything all together?
Is there a wiring diagram here online that would tell me all the wires to tap into for example
1. Alternator/ Tach Sensing
2. Foot Brake Inpute
3. Door Trigger input
4. Door Trigger input (Negative)
etc
I need that kind of list
etc
