Fuel Capacity Question
Well, actually you probably did get over 40. If your odo is like most with factory tires, it underreads milage by about 4%. So, add about 16 miles to that total and you will be over 40!!!
Walt
Walt
Walt
Walt
Originally Posted by jethro b
Don't fill the filler neck!!! Thats a whole nother problem with your charcoal filter system. You may end up throwin a code.
Walt
Walt
they would go on long trips and watch the mile markers on the side of the road....
say you start at mm 4...write down the odo milage
travel to mm104. that is 100 miles traveled on the road
now check the odo milage again...it will be around 95-96 miles
check out this thread...
https://www.scionlife.com/forums/vie...t=odometer+low
Walt
Walt
Music City Scions
There was a topic about what happend to one guy that did that. It ended up contaminating his charcoal filter system and not being covered under warranty cause it was his fault
(big can o worms). It ends up going into the vent system and causing all the problems. I just fill it to it clicks then round up the price a few cents just to be safe.
I'll be out of warrenty in a few months anyway
By way of follow up....day before yesterday, as I pulled into my garage, the fuel light came on. Next morning, hopped in and starter her up, no light, but needle near E. Drove about two miles to fuel station. Filler 'er up and ... bingo. The pump shut off right at 9.9 gallons. I was able to squeeze just a bit more in for a total of 10.171 gallons. The comments here have been spot on in terms of capacity.
bootlgr
Jan 26, 2016 01:22 AM
