Help!! ASAP Please my part fell down the ac pipe
Ok guys so i was working on my xB. And then i was all done putting it back together and as i was snapping the center unit back together i noticed that the ac vents ball thing was loose so i tried to push it back in and the plastic piece
is long gone now. This is what it snaps to on the side
2nd view
This is what it looks like when it is snaped on
I was wondering if anyone knows where i can order this part. Cause the vents keeps falling down. Any help would be good thank you
-Devin
Sorry i do not know how to use the tags
2nd view
-Devin
First off, you can order the part at your Toyota Dealer.
Second, you probably won't need to. Taking the upper dashboard off takes a little time, but it's pretty straightforward and gets you access to your vent ducting.
OR, try this. Get a pretty good vacuum cleaner, like a shop type vac. Attach a small tube to it and snake it down slowly and matbe pick it up. If you clean out the vac first anything that gets sucked up will be easy to find.
Walt
Walt
Walt
Walt
NOTE: One of her fishnets will not work!!!!
my06tc
Jun 25, 2015 12:18 AM
JM Auto Racing
Dec 19, 2014 06:36 PM
