REAR drum brakes
Originally Posted by itsjustmatt23
Does anyone know how to take the rear drum brakes off? I wanted to check my brake wear and i couldnt get the thing off.
actually with drum brakes to get the drum off you just take off the wheel, smack the face of the drum a few times with your patented fix-everything-under-the-sun tool, aka the BFH (big frickin hammer) and just pull it straight off.
the hammer loosens it up so you can pull it off since it is pressed on very tight from when you tighten the wheel into place.
These fancy foreign cars! What will they think of next!!!
I was just going off any other car with drums I have ever worked on, plus its always fun to beat things with the 5 lb hand held sledge.
I recomment you not use wheels spacers. Instead use the devices / inserts sold by One Ton garage to move the entire drum assembly out 9MM. This makes the back spacing to the wheel opening the same as the front and solves most rear wheel clearance issues. Much safer than wheel spacers and then you do not have to worry about longer studs. The installation is simple.
Slopoke21m
54
Apr 23, 2007 12:25 AM
