Removing door panels.
Team Sushi
OK, Jeremy. . . why must you kill me man?
Step 1: Remove the Platic trim on the C Pillar/door (that platic piece on the rear side of the window that runs from the bottom of the door to the top). It is held in by clips, so be careful not to break them, although it does take some force.
Step 2: Remove the screw located inside the hole/cubby/grab handle on the armrest of the door.
Step 3: Lift that entire plastic piece up and out (held in by clips and that screw you removed).
Step 4: Pull the wire harness plug. connecting the window switch to the door
Step 5: Remove the screw inside the door opener latch (the thing with the lock on it).
Step 6: Now the rest of the door is held in by clips, simply lift the top edge of the door up (out of the window sill), and the rest of the door is held in by clips. It will take a tricky move to maneuver around the door latch handle (it might help to pull the handle as you pull the door off).
Step 7: PM djct_watt and tell him how cool he is, and how he is the King Shizzle.
