Scangauge question
NOt sure about the newer software but the gauge stops measuring fuel used if you exceed the size of the tank so setting it to 11 does not measure past 11 and if you are off a little or want that last 0.9 gallon reserve you can't tell how much of it remains as you use it once you go past 11 gallons. I find that the low fuel light comes on very consistantly at 10 gallons used from full so if you check fuel used at that point you know how accurate the reading is.
bootlgr
Jan 26, 2016 01:22 AM
