shift knob boot too short
so i got a new razo 117 shift knob and it feels awesome, but upon hooking it up i noticed the shift knob boot doesn't reach the shift knob. how do i fix this?
https://i17.photobucket.com/albums/b...hiftknob15.jpg can i get under the boot somehow to raise it up? it'll reach my shift knob, but it won't stay up there. do i have to buy something else? a clip perhaps? any info you got is much appreciated |
Turn the chrome peice around on the boot. That should get it closer.
is it really that simple? i'll try it out
not that simple.
the plastic chrome-looking piece turns, but so does the whole leather boot with it. and since the bottom of the leather boot is attached to that silver looking bottom piece, the chrome-looking piece only turns so much. there's also some sort of clip or bolt underneat the boot about an inch or so underneath the chrome-looking piece. i tried turning that to but couldn't notice much of a difference. any other ideas |
You just need to go to Wal-mart and get a Boot-stretcher, the one with the green handle should work just fine.
It is in a cone shape so by flipping it it will get you closer to the knob. Just be careful and you wont break anything. Our cars are like legos. |
My shift knob had the same issue. There is a simple fix. Snap the silver bottom boot ring out of the console. Pull the boot inside out up over the shifter knob. Slide the boots ring up against the bottom of the shift knob. Hold it there and install a 1/4 wide wire tie strap around the shifter shaft to hold the chrome ring against the shift knob. If you want to be double sure it doesn't slip down apply a little strip of 2 sided tape to the shifter shaft first the then tie strap over it. Pull the tie strap very tight before cutting off the excess. Pull the boot back down into place and snap it back into the console. I did not use any 2 sided tape under my tie strap and it stays in place pretty well tho every now and then it slips down just a little.
sweetness!!! thanks guys!!!
i didn't snap the silver ring out, but i snapped the leather boot out of the silver ring. and i ended up just putting a rubberband around the shifter shaft to hold up the chrome piece and it worked out all the same. the leather boot does look a bit stretched in 5th gear but its all good the finished product https://i17.photobucket.com/albums/b...ftknob15-1.jpg thanks a billion ya'lls |
a-ten-HUT! :P
