VSV purge valve on my 06' XB making bad clicking noise
Old Dec 14, 2008 | 05:42 PM
kirbyts's Avatar
Default VSV purge valve on my 06' XB making bad clicking noise
On my 2006 XB the purge VSC valve that was connect to my factory air cleaner housing is making a Clicky noise. It sounds like a marble from inside a spray paint can. It gets faster as the RPM is increased. I had replaced the factory air box with a AEM cold air kit like two years ago with no problem. I have 30000 miles now on the XB and it has started to make noise. I can actually hear it in the cab of the XB when driving now so it is time to fix it. I have removed it and blown it out thinking some debris might be in it did not help the situtation. Does anyone have a OEM part number for this piece I think I will just replace it, I live in Canada so I can't just walk into a Toyota dealer and look up a part number. I have never had the VSC unit secured with a bolt since I replaced the air cleaner but it is at the same angle and postion it was before with the factory air box so I doubt it this would be an issue. Any help on this situation woulds be appreciated.
Thanks,
Kirby
Old Dec 14, 2008 | 05:47 PM
sdsnybny's Avatar
I'm not sure about how to check if its defective or not but I can share some links for all Toyota/Scion Shop mauals
ie; repair-diagnostics-wiring-parts
pm coming.
RayScionXB
Regional - Pacific South
19
Mar 5, 2015 08:22 PM
meowtc
Mar 5, 2015 02:28 AM
RayScionXB
Regional - Everywhere Else
Mar 3, 2015 08:27 PM
32
Nov 5, 2003 03:49 PM
TheRedBox
Oct 21, 2003 09:47 PM
