Before air...
Thanks for looking. My UAS should be arriving soon at which point I will dump the shiet out of the car.
I believe I'm the 2nd xB2 with AME's but I'm the first with the the most aggressive AME's. I have 2cm of poke in the rear with 5 inches of JDM lip.
Originally Posted by scion619
hey nice to see another gen 2 with ame's looks good bro.....whats the specs on the rims man? speeking of air I'm right behind you I'm still waiting for my airrunner to come in...........
18x8 +40 hi disk
18x10 +32 super low disk.
UAS for me.
Team No Limitz
So you dont plan on going to much lower then huh? Cause by looking at the side view the wheels stick out past the fenders and will sit right on the tire. So you might get about another 2" out of it in the rear.
That is if you tuck at all.
I thought I was cutting it close with my 9's in the back with a 35 offset...im thinking your gonna have to pull and roll the fenders in order to competely slam it..... I give you props on running 10's though I think you might be the first to do so....
Originally Posted by detroitbassxb
You def won't be able to tuck. You will need to roll those fenders a crazy amount. Air ride would probably just be a waste...
Who said anything about tuck?
JC
It's not about high offset. Look at your pictures. Your wheels/tires stick out past the fender. Air ride would only be able to drop you another two inches before you hit the tires.
looking good man... just grab a five axis kit and let the air out...
loving those 10s in the rear.. thats how you do it..
what size tires you have now.. If it was me i would have went with full strech with a 205/40/18 on that rear rim.. that off set is perfect Poke! never mind letting the tire kiss the fender.. let the Rim lip kiss the fender.. Without Camber..
255/35/18 on there right now.
