LEVEL OUT the XB?!?!?
Is it possible to level out the overall stance of the XB?
In other words, is there a lowering spring for the rear only that will bring the back end down to the height of the front? I use my XB to haul my DJ equipment, which can be heavy depending on what I bring out. I am worried that if I lower it any more than where the front already stands, I'll be rubbing....which I DON'T want.
I have searched this board and others. All I could come up w' are answers for the 1st generation XBs. Thanks in advance
The rear wheel arches sit about 1.5" higher in the rear than the front. TRD rear springs have a 1.5" drop and are a little stiffer than OEM rear springs. If you look around you can probably find somebody selling a used full set for a good deal, and throw on the rear springs only. Eibach ProKit rear springs have a 1.2" rear drop, but far far fewer people get these springs than those who get the TRD's then decide they would like to go lower later.
Eibach Sportline's give a 2.2" rear drop and a 1.2" front drop. It literally looks perfectly equal. They are firm, also. I also forgot to add that regardless of who I have in the car, fat or skinny... or just a bunch of stuff.. the rears will decline the same as the front, regardless of where the weight is. It becomes evenly distributed, once you add "X" amount of weight (one fat person in the back), and then you add "Y" amount of weight (another fat person), the springs get ridiculously stiff... They are excellent.
2008-2012 Scion xB - "Air Lift 1000" Air Helper Spring Kit (Rear) - Air Lift 60823 under $100 bucks
http://www.suspensionconnection.com/cgi-bin/suscon/60823-scion-xb.html
Add 1,000 lbs. level load capacity with adjustable air springs for hauling or towing!!!
Air Lift # 60823 "Air Lift 1000" air bag helper springs keep your Scion xB level and riding comfortably when hauling or towing. These totally adjustable air springs mount inside the existing coil spring of your Scion xB to provide load control through the use of air pressure. Rated at 1,000 lbs for additional level suspension load capacity. All Air Lift air bag helper springs are custom fit for a simple bolt-on installation. An optional air control kit (air compressor kit) can be added (not required) for additional convenience.
Yea, Cory James did it, but I don't recommend running rear springs from a car that weighs 600 pounds less. Might not be too dangerous when empty, but definitely not a good idea when loaded with passengers and/or cargo.
So, I installed the ProKit rear springs today. Took me all of 20 minutes; love working on the box! Here are a few crappy cell phone pics. I think it looks pretty good, but now with the wheel closer to the top of the fender, it really accentuates how far IN the wheel sits. Time for some 20 MM spacers out back - and wheels, of course!
Yep, it's pretty much that simple. Here are all the steps:
1) Jack up the rear and put it on jackstands (on the "frame", so the rear suspension is free to extend)
2) Put a jack under one side of the torsion beam and put just a little pressure on it.
3) Remove the lower shock bolt on that side.
4) Drop the jack down until that side of the suspension is at full extension.
5) Pull out the old spring and transfer the rubber isolators to the new spring (the lower isolator may stay on the torsion beam, which is fine; just leave it there).
6) Install the new spring and raise the jack until you can reinstall the lower shock bolt.
7) Drop the jack down and repeat on the other side.
The only thing that worries me about the TRD rear springs is the 1.5 inch drop. The Eibach Pro Kit springs I'm using have a 1.2 inch rear drop and it has the car sitting VERY level. I'm wondering if the extra .3 inches might cause it to sit TOO low in the rear.
When I measured from the ground to the center of the fender arches on my 2008 xB, the rears where exactly 1.5" higher than the front. Measure for yourself, but I think the TRD rear springs should get it perfectly level.
Also, if I load anything substantial in the back (which I do 5 days a week), it makes the rear appear (at least to me) to be lower than the front. Just my $.02
