Need help with grille removal and placement.
Im looking to place some lighting behind my upp/lower grille and Place the xb elbem on there as well.
http://www.oznium.com/piranha-bar/action
see the TC and cobalt? thats waht i want to do.
Should look crazy nice. but i opened my hood. and i have no idea how i would get something in there.
Can someone help me or show me some picturees of how to get access to the upp n lower grilles?
and how to take off elblem from the back and put it on the grill in the front.
Here is a Link on how to remove the upper grill. Super Super Easy
http://trdsparks.com/install/PTS01-52070inst.pdf
For the lower grill you gotta remove the hole bumper or get under the car and remove the plastic skid plate / Splash Guard.
And you wanna remove the scion emblem on the trunk and place on the front/???
Heat gun and some fishing line. once removed you will see two holes where the nipples in the back of the badge went. Not like the first gen's that just stuck on.
Originally Posted by lvbitwiz
it's just stuck on, hair dryer or heat gun and fishing line (or dental floss)
But you sure you want to use the piranha bar? even they tell you it's not waterproof
Check this page on that site. It shows the products that are WATERPROOF. Most are better suited for the grill area because they are flexable. As a matter of fact, if you search the site you will see a scion area too. In there is a description of what the Xb used for the grills.... Seems like a 36" for the upper and maybe a 19" for the lower. Anyway, this page gives WATERPROOF data.....
http://www.oznium.com/flexible-led-strips
Good luck. I am wanting to do grills, under-body and wheel wells myself, but it will have to wait a bit longer.
to take the side vents and lower grill off You have to unbolt the nose piece!! 2 bolts in each wheel well and about 6 underneath the vehicle. A 10 MM wrench and a 12 should be all you need!!!!
Originally Posted by dspeedy69
hey how did you get that pdf on removing the grill, i want to know how to remove the all bottom grills on the fron bumper, i mean the little sides ones?
