Puddle Light On Five AD Kit
After getting some inspiration from NEAK on his thread...https://www.scionlife.com/forums/sho...=puddle+lights
I went ahead and purchased some from Sean @ http://www.ledmod.com
So...before I send the kit to Midnight Garage (Ross) for fresh paint. I decided to Dremel the holes and mock up the Puddle lights...
Here is a sneak peak on the process.
They sit so flush against the kit that you cant even tell they are there.
To Be Continued...
To Be Continued...
Nice install, thinking I may do the same. I noticed that the 1/2" hole looked a little out of round. If you're using normal twist drill bits, that will do it. I find that using a stepped bit gives a very nice hole without the usual three direction chatter that a twist bit makes. A stepped bit is almost all rim, with two cutting surfaces, so the bit doesn't have a chance to wander in the hole.
Dang, everyone is stepping up their game! Hey Digon, do you think it's possible to do this mod with the sideskirts STILL on the car? And, where does the wire come "into" the car? Where do you tap the wires?
Thanks for the compliments everyone. I cant wait until everything is put back together after paint.
also be sure you line it all up if not it might look weird.
i gave the job to Limitless.. i think its possible so long as the car is up and you can fit underneath with a drill. i would think its possible to do with it on the car albiet a little difficult if you cant get the car high enough
