2009 Scion xB auto tranny/ no neutral, no reverse
Old Mar 23, 2015 | 02:23 AM
26scionxb26's Avatar
Default 2009 Scion xB auto tranny/ no neutral, no reverse
Ok so I got a "new to me" 2009 xB...got a CEL that the SLT solenoid was stuck. I dropped the valve body checked all the solenoids (all were good) put it all back together and went for a test drive. When I put it in reverse the car went forward, in neutral it went forward...etc. I have no reverse and no neutral. What did I miss putting it back together? I appreciate any thoughts/help.
Old Mar 23, 2015 | 08:58 PM
zfxp's Avatar
you made sure everything lined up correctly, right?
Old Mar 23, 2015 | 09:07 PM
Yes everything lined up right. ..the only thing I'm not sure about is the larger shaft/plunger on the driver side front. I'm guessing it's the shifting "linkage" maybe it needs to be set in differently
Old Mar 23, 2015 | 09:52 PM
zfxp's Avatar
Yes sir, that's exactly your issue, take another crack at it. place it in neutral then line it up.
Old Mar 23, 2015 | 10:14 PM
Yep! I just dropped the pan and saw it right away. Thank you very much!!!
Old Mar 23, 2015 | 10:18 PM
zfxp's Avatar
Glad it's working bud!
so I assume you're all good to go?
Old Mar 23, 2015 | 10:26 PM
Should be...I'm putting it back together now...then a test drive. I'll let ya know later tonight. Much appreciated
Old Mar 24, 2015 | 05:36 PM
Ok...now the solenoid code is gone, but now I got a speed sensor code. p0793. How hard is that to replace?
Old Mar 24, 2015 | 06:56 PM
zfxp's Avatar
before you replace it, make sure all sensors and their connectors are connected.
It's on top of the tranny it should be underneath all of the air duct for the intake.
Old Mar 24, 2015 | 07:20 PM
Will do. It'll be Saturday before I get back to the car. Thanks for the quick response
Old Mar 29, 2015 | 11:52 PM
So i pulled both speed sensors. The output sensor looked fairly "weak" is the only word that I can think of to describe it. Both had solid connections and ohm tested correctly. I've ordered 2 new sensors hoping that will solve the problems.
Old Jun 11, 2015 | 12:48 AM
JZ813's Avatar
Did it work? I have 103k miles and I'm throwing a sensor code but it tested ok
pro710
Dec 29, 2014 06:52 PM
yamahamx117
Scion xD Suspension & Handling
Dec 25, 2014 01:54 PM
ScionLife Editor
Dec 6, 2014 11:58 PM
gularti
Dec 4, 2014 01:21 PM
ScionLife Editor
Nov 20, 2014 05:20 PM
