2011 Scion tC Clutch Replacement..
Does anyone know where to find the torque specs for the clutch and flywheel? It seems like the 2011 tC's are almost invisible online.
Thanks!
______
Thanks!
______
If you can't find torque specs for Scion tC, try searching other Toyota, Scion and Lexus models with the same engine/transmission combo.
Or even possibly search Toyota Zelas as this is what the Scion tC was called in other markets.
One thing though, be sure to dab a tiny bit of locking compound on the bolt threads as the pressures on the bolt-heads are such that the motion of the pressure plate is trying to lift the bolt away from the flywheel......if that makes sense.
Thank you for your reply. I ended up using 35Nm and a 90 deg turn with Loctite. Hope this does the trick.
I decided to replace the bearings inside the transmission. Do you know where I can find a manual for the EB 60 transmission? I need to know how much gap needs to be for the input shaft snap ring. I have the chart for all the sizes. I need to find out how to check for it and where to check.
Thanks,
Thanks,
immeadows
Scion xD Drivetrain & Power
13
Aug 22, 2012 11:16 PM
PTUNING
Nov 18, 2011 02:22 PM
