GGP Engineering NEW PRODUCT RELEASE
5 December 2008
Phoenix, AZ
For Immediate release:
GGP Engineering was established with one simple mission:
To make the best possible products.
Our mission is to manufacture high quality products designed to provide our clients with a durable competitive advantage. Our founder’s objective is to ensure that each customer, every day will benefit from the highest quality components that money can buy. We deliver personalized customer service with exceptional attention to detail.
The GGP Engineering benchmarks adhere to the highest standards of quality.
• Extremely close tolerance – Our designers and technicians measure to the thousandths to ensure precision fitment.
• Only USA manufactured parts, material and labor.
• We utilize only the highest grade of tool steel, aircraft grade alloy, and component pieces.
• Designed and engineered by experts –aiming to meet and exceed customer expectations targeting ease of installation.
• Life time limited warranty of all GGP Engineering products
• NO COMPROMISE ON QUALITY
Front lower motor mount 05+ Scion tC 08+ Scion xB
When preparing your Scion for club racing, autocross or spirited street driving, eliminating flex in the drive train is a top priority. This innovative product helps deliver full power to the wheels. The GGP Engineering motor mounts are constructed under the highest standards of quality and precision.
The mount is machined from aircraft grade 6061-T6 aluminum and paired with the perfect formulation of polyurethane co-developed with Energy Suspension® to withstand high horsepower and high torque applications. Designed using sophisticated CAD/CAM engineering software, this component provides the utmost in strength and fit while adhering to strict ISO 9000 quality standards.
This mount is not required to be pressed into the factory housing. Simply bolt in the factory location using your OEM hardware. This mount it computer engineered and track proven!
This is the Prototype mount. Final version will be anodized tarmac grey, laser engraved with GGP Engineering logo and will be available for purchase 12/12/2008.
Originally Posted by boooosty
Can somebody cliffnote what this thing does?
Team No Limitz
ah ok, by the looks in the post it was one piece fit both. Just wanted to be clear. Looks like it is going to be a cool piece for sure. Might have to look into this.
This will not act like a damper, just the opposite, you may feel more engine vibration. OE mounts absorb some of the vibration, this may amplify it, these are good for competition but maybe not so good for every day use. Just as urethane bushings help a suspension work better but deliver a stiffer ride, these should work the same.
So, this will act similarly.
:D
It's almost like solid motor mounts on an old Chevy.
i have the stiffy and you get alot of valve thain noise. i added polyurthane washers i cut from aenergy suspention bushing and it made it more tollerable.as long as there is metal to metal you will get noise.[the bolts]i will try this motor mount because there might be no metal to metal.
:D
This single mount should have less vibes and be more comfortable to the daily drivers than a engine damper.
Usually the extra vibes from an single mount is un-noticed unless you pointed it out.
Can these be picked up locally?
how did i miss this i need thiss i kinda broke mine lol i dont know how i think when my boost hits its a little much for my mount whats the price/ on this hook a brother up with the mani to like a package deal
