Scion xB Transmission problem..
Old Jun 16, 2021 | 09:37 PM
Karo_B's Avatar
Default Scion xB Transmission problem..
Hello everyone, sorry in advance for my English, I usually speak French.
I recently had transmission problems with my 2015 Scion xB.
When Reversing, the vehicle does not want to cooperate.
What should I do?
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; Jun 17, 2021 at 10:06 AM. Reason: Moved to Correct Forum by Administrator
Old Jun 17, 2021 | 07:58 AM
Low_Kei's Avatar
And is it automatic or manual transmission? If it’s automatic, check your fluid level. If that’s okay, the. Look in to replacing your shift solenoid for reverse.
Old Jun 17, 2021 | 01:53 PM
Karo_B's Avatar
Thank you for your reply. My oil level is good, but I am told to change the oil because it is a little dirty. Hope this fixes my problem. When I went to the garage they told me that transmission problems are usually very expensive, due to the labor. They told me that if the oil change didn't help my problem, I was going to have to replace my complete transmission. I also did not have a diagnosis. I thought I could have an estimate that would tell me what repairs to do ... I will change the garage I think. thank you
Old Jun 17, 2021 | 04:21 PM
DannoXYZ's Avatar
Moderator
Moderator
very odd, these transmissions are very reliable.
Problems are typically electronic.
Switches in shifter mechanism is 1st test as they tell ECU what position shifter's in.
Then solenoids in transmission does actual shifting that ECU commands.
Old Jun 17, 2021 | 09:27 PM
Karo_B's Avatar
I bought this used car last October. So it's only been eight months since I have it. If it's an electronics problem, what will be the thing to look for to find out the cause of the transmission problem?
Old Jun 18, 2021 | 01:17 AM
DannoXYZ's Avatar
Moderator
Moderator
Test switches at shifter.
Test solenoids, these usually only need cleaning. Replace if they fail test.
scionxbpr
Oct 21, 2013 09:32 PM
scionxbpr
Oct 21, 2013 03:37 PM
striker79
11
Apr 20, 2007 05:25 PM
dieselstation
Feb 22, 2007 08:48 AM
JoeDarkness
31
Sep 19, 2005 02:54 AM
