Throwin' Codes
My buddy (lefty29er) just installed a strup header last weekend. I seen he had the cel eliminator on the header, so we pulled out the instruction manual that it came with and it said specifically to install it on the header. I'm not saying it's right or wrong or if thats even related to your issue but just thought I would add that.
The CEL eliminator goes on the secondary O2 sensor in the S-pipe after the header. It works by making the sensor read a leaner AFR which is how it would be if you still had the primary cat burning off fuel that wasn't burnt during the internal combustion process.
To the OP:
As Trevor suggested, find out what the code is first. If it's a P0420, try rotating the CEL eliminator so that it faces away from the direction of gas flow. This worked for me and I haven't had that code in 2 years now. Also, the TCS and VSC systems are both turned off when you have a CEL so that is why you've lost traction recently. GL
vi3tb0i09
Sep 23, 2015 08:32 PM
wayneside
Regional - Pacific Northwest
Sep 23, 2015 10:29 AM
