TRD or Strup exhaust??
Well I had one hell of a craigslist find, and got an Injen CAI, a Strup header, a TRD exhaust and a Strup exhaust from a guy for peanuts. I've already installed the CAI, going to be parting with the header, and am wondering which exhaust would be the one to keep and install? I'm not looking to make the car sound annoying and rice-ish by any means, just a bit better of a sound. Def. not looking to have an annoying drone in the cabin either. All input is welcome.
Ok, well it seems that from everybody's response that the Strup exhaust is the way to go. Thanks for the input.
As far as the header goes, i really have no issue installing and using it, but I don't want it to be a bigger headache than it needs to be. I know that i'll need a cel eliminator to use the header, thats not a problem, but which cel eliminator would be the best to use? I've heard some are better than others. I know the pros of using the header, but what are the cons or problems that I may run into or have to deal with?
Thanks again for all the input.
and as for any downfalls with the header..you may get a CEL and the you remove one of the cats for emissions..
The only con I'm aware of is if your emissions inspection requires both cats be present to pass, then pulling the OE exhaust manifold (which includes a pre-cat) will be a problem. At worst though, you'd have to temporarily swap back until you pass emissions. I'm sort of interested in the W-R Header, but am concerned Delaware emissions inspection would object (given the car came with two cats).
I also stopped into a local exhaust shop today to get a quote to install the Strup, and asked about the header and yearly emissions inspections. I asked if they actually looked for the components or if everything was good as long as there was no CEL on. From what this guy said, as long as there's no CEL light on, it should be fine, but he was wary saying that he's seen a fair share of problems pop up with emissions.
So, on that note, I think I'll just get the exhaust work done, and part with the rest.
Well I'm looking to have it done before this weekend, since I'll be taking a trip to Pittsburgh. Normally it wouldn't be a problem to do it myself, but with my job, I'm on call tonight and tomorrow night. With my luck I'd get half way into installing it, and get called into work. It's just easier and more time efficient for me to have someone else take care of it for me.
I have the TRD axle back that came with the RS7, the thing is really quiet. I would say barely above a stock muffler. I also have the Strup Ceramic Coated header and Strup CEL eliminator that i will be putting on soon. Depending on how it sounds after the header i may do some more work to the exhaust.
As far as CEL eliminators go, the only two i know of are Strup and Weapon-R (maybe there are some other ones on ebay??) I know that the strup one is stainless steel that might be something you consider cause you said you live in NY. Besides build quality and material, i think they all are pretty much the same and do one thing, which is move the 02 sensor out of the exhaust flow
DJ_FroZone
25
May 30, 2019 07:17 PM
airmankevin1
Feb 14, 2018 01:23 PM
stankubrick
32
Nov 24, 2003 03:43 AM
