TRD Supercharger 08 xB
Originally Posted by bBlover
Originally Posted by -Devil-
hmmm is it intercooled?
A top mount wouldnt be a bad idea if some kind of ducting was made to allow air to it but even then that isnt the most efficient setup hence the mazdaspeed 3. But then you can have a hood with a scoop and its all good!
GF has an MS3
GF has an MS3
last supercharger i ran .. i was pushing 16lbs of boost ... without the intercooler up front .. the motor would have died a long time ago ...
after looking at this kit a bit more, i think i would just wait for other aftermarket .. and relocate the battery .. so that one could be added ...
the reasons are that if you can choose between a trd supercharger with a warranty, and another supercharger that isn't warrantied, which would you choose? an aftermarket supercharger wouldn't make more hp, or be more reliable, or have te best cost, be more complete, be properly tuned? so that is why most aftermarket forced induction kits are turbochargers instead.
also, i think the "extended drive shaft" for the trd supercharger is patented by toyota, so that might prevent other manufacturers from making their own supercharger.
i would choose the one that gives me more freedom ...
and there are as many aftermarket FI kits out that are superchargers as well .. just so many are hooked on turbo ..
the driveshaft you speak of is not patented by toyota ... it is most likely a vortech product that is being built for toyota ... vortech has had systems out for quite a while now using the same kind of shaft setup ... mostly used on honda / accura motors though ...
and ProCharger has setups that work as well, but without the shaft .. it just has the S/C mounted in a different location ...
there is always a way to get something else onto a car ... yes the factory warrenty is nice, but i prefer the freedom to custom tune or tweak a setup as compared to a 'locked' setup with little options for upgrade ...
which one will i go with? ... only time will tell ... but whatever system it is .. it will have an intercooler ... if nothing other then one of the small air / water setups from vortech squeezed in there ...
Youd be spending more money to make a custom s/c kit for this motor than you would purchasing and "tweaking" the already existing s/c. I only see reliability as an issue with this supercharger. The power potential has already been proven...
the 200hp guess i would say is off a bit ... and the 7 lbs non-intercooled is pushing it ... less the programming is set so rich that it won't detonate ... which would explain the low numbers ...
it should be hitting in the 230 range ...
and i would always prefer a S/C over a tc
