2014 xB Center Auto Trans Shift Console Bulb burned out
Hey, you guys my 2014 xB Center Auto Trans Shift Console Bulb burned out.
How do you get to it? Help!! Thanks in advance! |
Grab the trim panel around the gear selector panel by the lower edge and pull up. It's held in my snap clips and will come right up. Once you have it off you can see what type of bulb you need to get. I recommend replacing it with an LED bulb if possible as they last a lot longer.
Hi Greg S Thanks I have the panel off and the shift assy. at the bottom below has 2 screws do I remove those and pull the shifter assy up and turn side ways to see the bulb. It looks like a wire going up to the left of park on the shifter, is that going to a bulb? Should I pull it out?
I'm worried I will break something. Thanks for the help! Andy |
Unfortunately I don't know since I have a stick shift. That sounds like it should work though.
