2014 xB Center Auto Trans Shift Console Bulb burned out
Hey, you guys my 2014 xB Center Auto Trans Shift Console Bulb burned out.
How do you get to it? Help!!
Thanks in advance!
Thanks in advance!
Last edited by MR_LUV; Jun 4, 2018 at 06:09 AM. Reason: Moved Thread to Correct Forum by Administrator
Grab the trim panel around the gear selector panel by the lower edge and pull up. It's held in my snap clips and will come right up. Once you have it off you can see what type of bulb you need to get. I recommend replacing it with an LED bulb if possible as they last a lot longer.
Hi Greg S Thanks I have the panel off and the shift assy. at the bottom below has 2 screws do I remove those and pull the shifter assy up and turn side ways to see the bulb. It looks like a wire going up to the left of park on the shifter, is that going to a bulb? Should I pull it out?
I'm worried I will break something. Thanks for the help! Andy
XbbbbBox
11
Nov 8, 2014 10:56 PM
martymcfly
13
Nov 8, 2014 09:29 PM
SoleLaced
Scion tC 1G Aero & Exterior
Apr 12, 2008 06:25 PM
rwf
Nov 1, 2005 01:34 AM
