2015 XB lights out
Old Sep 8, 2022 | 12:30 PM
semscion's Avatar
Default 2015 XB lights out
My interior lights on my 2015 XB for the 3 round A/C temperature, vent control ***** as well as the gear shift indicator lighting is out. I have not done any maintenance or mods recently, simply noticed they are out. I have not checked anything yet, wondering if this is a common issue with this car? Would one fuse be for these lights mentioned?
Old Sep 8, 2022 | 01:00 PM
semscion's Avatar
Further investigation indicates from the interior passenger compartment fuse box, Fuse no. 2, For instrument cluster lights, instrument panel lights, gauges and meters should be correct fuse, but all other items assigned to that fuse are not out? Checking that fuse now.
Old Sep 8, 2022 | 01:42 PM
semscion's Avatar
Fuse is good.
  • Do the 3 round control ***** light up, or just the orange lighted on/off push switch in the center of the ****? (Just the orange switch is illuminating)
  • Does the gearshift area illuminate by the gearshift ****, or just the digital gear indicator on the dash? (Just the digital dash gear indicator is illuminated)
I'm thinking it may be all good and I'm losing my mind, if someone could confirm what should be illuminated in these areas, I would appreciate it.
Old Sep 8, 2022 | 05:05 PM
Greg S's Avatar
May sound stupid but have you tried the dimmer ****?
Old Sep 8, 2022 | 05:24 PM
semscion's Avatar
Greg, yes that's the first thing I tried was the dimmer **** which works on the digital dash up above. What I was wondering is those three round ***** on the center for the AC and vent controls are they supposed to be lit up? Along with the gear indicator is by my shift **** should that be lit up it just looks darker than it used to be.
Old Sep 8, 2022 | 10:31 PM
semscion's Avatar
Stole this photo, disregard the red circle. Should the background on the three round ***** light? The letters for the shifter/gear indicator.
Old Sep 9, 2022 | 05:29 PM
Greg S's Avatar
Yes the three ***** should be backlit amber just like the dash. The bulbs used are small incandescent ones and they can become loose over time. I've replaced mine with T4 LED bulbs, but it's a bit of a pain to get to them as the controls have to be removed from the car to do it. As dumb as it sounds try smacking the side of the console to see if they flicker back on. If so then you know they are loose. As for the gear indicator, I'm not sure since I drive a stick.
Old Sep 9, 2022 | 11:39 PM
semscion's Avatar
All working this morning. I cannot explain it, no flickering, no hesitation, just plain working. Maybe when I removed/re-installed the fuse? I'm happy but clueless.
Thanks for your input, Greg
Old Sep 12, 2022 | 05:26 PM
Greg S's Avatar
I'll take bets on the bulbs being loose in the sockets. Not an uncommon problem unfortunately.
BoukiBoi
Scion tC 2G Aero & Exterior
Oct 22, 2020 03:12 PM
GearReview
May 21, 2019 04:13 PM
acyix
Oct 14, 2017 01:55 AM
blue_xB_23
Mar 19, 2015 10:29 AM
alank2
Jan 23, 2015 01:17 AM
