Best place to find switched power under dash?
Got an OEM Toyota autodimming mirror for my 2015. Several mods to make it fit. The instructions say switched power is at the front dome light-checked not there only ground and constant 12v. Anyone know where to pickup switched power under the left side of the dash?
Going to pull the left a-pillar trim and run a wire, but color for switched power on the car would be helpful before tearing into everything. Worst case I tap into the power port, but ideally find something closer to the left side of the dash.
Accessory Positive Wire (+): Black
Accessory Positive Wire Location: At Ignition Switch Harness (White 8-Pin Plug, Pin #3)
or use remote line from radio harness to trigger relay for power pulled from elsewhere.
