Door rattle/sound Quality...
Old Jul 23, 2008 | 06:49 PM
ShaffNasty's Avatar
Default Door rattle/sound Quality...
So the inside plastic on my front doors rattle when the bass hits. I have stock speakers and stock head unit. My listening set up is Bass 3, Treb 5, Loud Mid, SPL Feel, and xB setting...
I plan on upgrading the speakers and am wondering if eDead will stop the plastic from vibrating so much or what?
Old Jul 23, 2008 | 07:30 PM
randomsuper's Avatar
edead will do the trick just fine. be sure to put some right around the door handle. i had buzzing there and it pretty much eliminated it. just take your time and use more than 1 layer. you won't regret it.
Old Jul 23, 2008 | 08:30 PM
ShaffNasty's Avatar
should i put it on the door and the plastic door panel... Because it is the door panel that vibrates and bugs me...
Old Jul 23, 2008 | 09:17 PM
CIONIDE's Avatar
Duct tape and a glue gun can fix anything!
Old Jul 23, 2008 | 10:08 PM
ShaffNasty's Avatar
^ this is very true, but i was wondering if there was a less ghetto fabulos way to fix the problem...
Old Jul 24, 2008 | 04:28 AM
lay it on both the actual door panel and the metal where it connects to. more work and kind of a hassle but absolutely worth it in the end.
Old Jul 27, 2008 | 05:49 AM
AndyInOC's Avatar
I put 4 coats of edead v3 liquid on the inside of the door, with a layer of edead v1 over that, 2 coats of v3 on the door structure with a layer of v1se over it and all holes sealed, and pieces of v1 on the actual plastic panel in strategic locations and my doors are solid, knock on them and they sound like solid wood instead of tin cans
Old Sep 2, 2008 | 02:32 PM
DJ_FroZone's Avatar
so what is edead? link? and how does duct tape n glue work???? im kinda broke soooo
Old Sep 2, 2008 | 09:46 PM
NoLimitzBuilt's Avatar
Team No Limitz
I had the same issue. I did a layer of Dead Skin on my actual doors. Then I cut it into strips and did it all over the actual panel also. Made a world of difference for sure.
Old Sep 3, 2008 | 12:56 PM
DJ_FroZone's Avatar
links again?
Old Sep 3, 2008 | 10:33 PM
xseveredveganx's Avatar
Utah Scions
Originally Posted by DJ_FroZone
links again?
Either www.yahoo.com or www.google.com. Great search engines. You just type in what you're searching for, and *BAM!* you get results and even more links!
Hope this helps!
*edit*
Just to help you out, I performed a quick search in which it yielded this result: eDead.
Unfortunately, it doesn't come in a Hello Kitty pattern, but that's okay cause you won't see it.
Old Sep 4, 2008 | 02:08 AM
DJ_FroZone's Avatar
links again?
Hope this helps!
*edit*
i swear on the prince of bellamy im going to flatten all your tires in your sleep.
*thanks
Old Sep 7, 2008 | 12:46 AM
emsmith2323's Avatar
woah
Schmohey
Oct 4, 2015 02:53 PM
Geedavell
Scion xD ICE & Interior
Sep 28, 2015 01:33 AM
atlantaemail
Sep 20, 2015 02:03 AM
EVILDAVE
Sep 15, 2015 06:54 AM
mcnick0495
Scion tC 2G ICE & Interior
Sep 8, 2015 02:58 PM
