Fuse problem need help
Old Jan 5, 2012 | 11:32 PM
siriusdesigner's Avatar
Default Fuse problem need help
So i was trying to hook up specialty lights to the interior of my 2011 xB but I blew a fuse but not the one under the driverside panel. I have no lights on my radio or the climate control panel. Is there a fuuse somewhere else that I'm missing. I check all the ones in the normal fuse panel but all of them are fine.
Please help.
Old Jan 5, 2012 | 11:44 PM
CIONIDE's Avatar
There's another fuse box in the engine compartment, near the air filter box.
All the fuses & functions are listed in the manual; there are several different fuses that control the radio (#12), gauges (#11), and A/C system (#10). You could start there.
Old Jan 7, 2012 | 09:43 PM
Thanks for the quick response, I have just tried those but the all seem fine. Is there one behind the radio or between the ignition and and that center dash area?
Old Jan 7, 2012 | 10:42 PM
CIONIDE's Avatar
Not that I know of. Since you lost the lights on the radio & climate controls, I would think it has to be a fuse in one of the two main fuse boxes.
Old Jan 7, 2012 | 10:51 PM
SamCarroll's Avatar
are you just looking at the fuses or testing them? I've made that mistake a few times only looking and they look fine but indeed are blown.
Old Jan 8, 2012 | 02:36 AM
Unhappy
Actually I bought a tester that sends a current through the fuse and then lights up if it's good. So far all have good. I even tested them two and three times because I figured maybe I missed one. But I still can't find it.
Old Jan 11, 2012 | 04:39 AM
Slody4Futbol's Avatar
Pull the fuses listed for the radio, check them that way. Or get a multimeter. I've seen those test lights give incorrect readings before.
Old Jan 11, 2012 | 02:03 PM
The radio still works. The LCD display is light up but the buttons are dark. I guess I'll have to pull them all.
idriveanxa
Mar 8, 2015 12:03 PM
EvalEvan66
Jan 27, 2015 02:26 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
EvalEvan66
Jan 16, 2015 08:34 PM
