!!!Help!!! Door speaker wire installation!
Old Aug 1, 2010 | 02:23 AM
MaxBoost925's Avatar
Default !!!Help!!! Door speaker wire installation!
Hey everyone.
So I tore apart my doors to install my new RF Power 6.5's into the doors. I ordered speaker adapters and they're on the way, but I cannot figure out how to run my speaker wire into the doors! Some input from guys that have already ran wires to their door speakers already would be much appreciated.
There are those ribbed rubber tubes that link the B-pillars to the doors but those are next to impossible to run another wire through. There's a plastic connector at the B-pillar side and it's taped up at the door side. I don't know how you guys did it.
Here's some pictures of what I'm working with right now, please don't pay any attention to the messiness. I'm just using that one speaker attached as a tester.
Old Aug 1, 2010 | 02:30 AM
randomsuper's Avatar
those are the rear doors right? what i did was take out the connector and used a drill to make a little hole in it. then i just slid the speaker wire through it. easy as pie that way.
Old Aug 1, 2010 | 02:33 AM
How did you take out that plug?
I tried tinkering for half an hour and I couldn't take it out.
Old Aug 1, 2010 | 02:43 AM
this was a while ago but i think i just yanked it out. i don't remember there being some special trick to it.
Old Aug 1, 2010 | 03:12 AM
Gah! I'll try again. How did you manage the front wires? Thanks for your input.
Old Aug 1, 2010 | 03:27 AM
for the front i used a coat hanger and some tape, lube, and so much swearing it was ridiculous. if i had to do it again, i'd make a small slit in the boot and run the speaker wire through it. would be much easier.
Old Aug 1, 2010 | 03:33 AM
TwztedtC's Avatar
Why take them out I always use the factory wires. I attach my wires coming from my amp to the harness behind the radio. Saves the headache
Old Aug 1, 2010 | 03:49 AM
KaneoheKoa's Avatar
I used 14ga wire in the front doors and that took a great deal of work to get it through the factory wire guide. I can vouch to Randoms use of lube, coat hanger and much swearing (please make sure any children are far away from you). I had to pull the boot off the door to thread the wire through. Made it a little easier, at least that's my story and I'm stick'n with it. Next time, I'll just make a hole in the boot and run my wire outside it.
Old Aug 1, 2010 | 04:56 AM
Some believe better signal is carried to the speakers via lower gauge wiring. Hence, they overdo it. But I think my 12 awg speaker wire is not overkill.
Old Aug 1, 2010 | 04:57 AM
And that's exactly what I'll do. Thanks for the pointer.
Old Aug 1, 2010 | 10:02 AM
buickid's Avatar
I've only done the front ones. Just jam it in there. Helps if you remove the boot from both sides (car and door side), scrunch it up, and then try to pass the wire through. Makes for a shorter length you need to get it through. Keep trying, it'll happen.
Old Aug 2, 2010 | 08:24 AM
Yeah, sounds like the correct plan of attack. Thanks.
Old Aug 2, 2010 | 04:40 PM
Greg S's Avatar
Like what has been said for the fronts just diconnect the ends of the boots from the a-piller and front doors and you can feed the wire through it. It is easier if you slit the boots just just after where they go through the metal. For the rears there are clips on the top and bottom of plugs on the outside of the b-pillers and a side clip on the inner half of the plug. From there you just need to look for a clear area to drill through for the wires to fit.
Old Aug 4, 2010 | 03:50 AM
omg.
My rear windows and doorlocks don't work. I took out the plug and drilled at the base of the plug and fed my speaker wire through. I made sure I didn't drill into any wires on accident and I reconnected it securely. I did break the clips though.
But now, my rear doors won't function at all electrically. I checked the fuses, they're still ok. I wonder what I have to do now.
Old Aug 4, 2010 | 03:54 AM
xseveredveganx's Avatar
Utah Scions
Originally Posted by MaxBoost925
omg.
EEP! No good! I haven't a clue. I haven't messed with the rear doors at all, nor will I.
Make sure all the window switches are plugged in. I know the tC, and more than likely the xB2, are similar. All the switches need to be in a circuit, otherwise stuff won't work.
Front doors were a big enough of a pain. I ran 16awg and I'll be running 2 sets of 14awg when I get the time. Time to go active...
Old Aug 4, 2010 | 04:09 AM
buickid's Avatar
Correct, the xB needs the window switches plugged in to work. The door locks, no idea. Got a DMM? Start checking stuff.
Old Aug 4, 2010 | 04:13 AM
Yeah. I assumed so.
I connected one side with the window switch but not the other. Tested it, didn't work.
Will try again tomorrow.
Old Aug 4, 2010 | 06:58 PM
Greg S's Avatar
Don't worry you didn't fry anything. Your molex plugs are not plugged back in fully. It happens to me at least every other time I pull the plugs apart to get more wires through there. You need to pull the wires you ran through tight while plugging the harnesses back together. it helps to have a second set of hands but can be done by one person. This reminds me that i need to fix the passenger side plug from the last time I pulled it apart.
Old Aug 4, 2010 | 09:08 PM
It was in there pretty tight. Like I said, I broke the clip so it doesn't snap in place anymore, but I forced it in pretty tightly.
I was thinking about cutting off the wires from the harness and then crimping them together, hardwiring them.
Old Aug 6, 2010 | 05:29 AM
Finished front doors, the rear door speaker adapters were the wrong ones. I ordered the ones for the rear of the xB1, didn't fit.
They sound pretty good. I have some serious midbass power now! But anyways, I fixed the rear doorlock issue, like Greg said, the molex plugs weren't all the way in. I now have a strange issue, when I press the lock button on my keyfob, the car will lock itself, but not blink nor make a beep sound. It happened before and went away by itself, I can't explain this glitch.
Ugh, my rear doors are still taken apart, but at least I have music again.
