Horn problem
One of my stock horns stopped working. Is there a way to check somewhere to see if a wire fell off or something?
Thanks!! |
Just look at it. :) they are visible through the grille.
If you want to get closer, remove the clips that hold the plastic cover in place between the grille and radiator support. you should be able to access them that way. If the wires are connected still, you may just need a new horn, or to re-ground the ones that are there in place. |
Thanks HATEnFATE!!
