Horn problem
Just look at it.
they are visible through the grille.
If you want to get closer, remove the clips that hold the plastic cover in place between the grille and radiator support. you should be able to access them that way. If the wires are connected still, you may just need a new horn, or to re-ground the ones that are there in place.
they are visible through the grille. If you want to get closer, remove the clips that hold the plastic cover in place between the grille and radiator support. you should be able to access them that way. If the wires are connected still, you may just need a new horn, or to re-ground the ones that are there in place.
danielv
May 20, 2016 11:05 PM
08SUPERWHT
Mar 21, 2016 10:35 PM
Jiminla
Mar 15, 2016 04:09 AM
