How Do You Remove Console Under Shifter On A 2008 xB??
Old Jan 24, 2008 | 06:34 AM
Raiders1960's Avatar
Default How Do You Remove Console Under Shifter On A 2008 xB??
I'm hooking up an amp for my subs in my 08 xB and I need to remove the console under the shifter so I can access the cigarette lighter wires. I want to tap into it so I can hookup my remote wire for my amp to it.
Old Jan 24, 2008 | 06:38 AM
bBlover's Avatar
wrong forum.
Old Jan 24, 2008 | 06:58 AM
SquallLHeart's Avatar
pull off the shifter panel first.
Old Jan 24, 2008 | 09:48 AM
rswscion08's Avatar
Pull on it after you remove the top covers. 4 screws and then physical basically. It does take some doing but its not hard to remove. just get the 4 srews first under the Tranny Cover!
Old Jan 24, 2008 | 02:42 PM
john08xb's Avatar
Yea i started form the bottom up..one pice holds 2 other peices..its a jig saw puzzle.
Old Jan 24, 2008 | 03:35 PM
bigpapa's Avatar
why are you using the cigarette lighter for your remote turn on? If your head unit does not have a remote turn on output it would be alot easier to access the ignition wire.
Old Jan 25, 2008 | 03:16 AM
Does the shifter panel just pull off or is it screwed in? If it has screws where are they located?
I was using the cigarette lighter for a remote wire because i thought it would be easier since I don't know where the ignition wire is located.
Old Jan 25, 2008 | 03:51 AM
Whispaz's Avatar
just pull
Old Jan 25, 2008 | 05:15 PM
bigpapa's Avatar
If you tap into the cigarette lighter your turn-on lead will be hot all the time......that means it will keep your amps on even when you get out of the car.
Old Jan 26, 2008 | 12:38 AM
By tapping into the cigarette lighter, why would that change when the lighter only works when the car is on or if it's on acc?
rjjablo
16
Feb 19, 2020 12:42 PM
carid
Nov 24, 2015 02:57 PM
GrumpyCat
Feb 10, 2015 02:52 AM
disaster06
Dec 4, 2014 07:05 PM
randode
44
Jun 29, 2004 04:19 PM
