new horn
Old Dec 21, 2007 | 11:05 PM
yanges's Avatar
Default new horn
i am looking at getting a truck type horn and was wondering if 16 amps is too much draw?
i figured if i had engine running when using it, there should be no problem...
Old Dec 22, 2007 | 12:43 AM
bigpapa's Avatar
You will need to use a relay off of your factory horn wire to pull power from the battery (the 12 volt wire under the dash is only rated at 30 amps and it needs alot of that while the car is running). You will also need heavy gauge wire running to the battery, probably 12ga or larger. I don't know what the amperage rating is on the factory alternator but I assume it isn't much. This may cause your lights to dim when you activate your horn if it is really pulling that many amps.
Old Dec 22, 2007 | 12:50 AM
Jan06xB's Avatar
Nooooooo the alternator is 90 amps the horn is powered through a relay directly from the battery with a separate inline fuse and there should be no problem. I plan on adding my air horns over the next few weeks myself FINALLY! I bought them for my first car back in the early 70's.
Old Dec 22, 2007 | 03:41 AM
Gothbox's Avatar
Default Re: new horn
what horn are you looking at?
Old Dec 22, 2007 | 05:15 AM
yanges's Avatar
here ya go Gothbox
found here:
http://www.airhorns.co.uk/product.as...234&deptid=121
Old Dec 22, 2007 | 05:19 AM
xseveredveganx's Avatar
Utah Scions
Quit messing around and get a REAL horn...
http://www.suicidedoors.com/4-PCTrai...ompleteKit.php
Old Dec 22, 2007 | 10:34 AM
rswscion08's Avatar
THats Not a Horn... THIS is a horn
http://www.hornblasters.com/installs...eets-marauder/
Probably drain the battery every time you use it though!!!!
Good Luck though seriously
Old Dec 22, 2007 | 03:17 PM
swartzautoman's Avatar
yah ...hornblasters is the real deal.
thay got alot of youtube videos.
Old Dec 22, 2007 | 03:23 PM
Jan06xB's Avatar
Hey you don't want to be breaking your own windshield!
Old Dec 22, 2007 | 03:51 PM
yanges's Avatar
i was looking for a deep truck sound and this one is pretty loud - i am sure it will do the job when necessary
Old Dec 22, 2007 | 04:41 PM
Jan06xB's Avatar
Yeah the longer the horn the deeper the sound . . . should have a slide and make it tuneable.
Old Dec 26, 2007 | 08:09 PM
Djbombsquad's Avatar
http://www.suicidedoors.com/showfull...Complete%20Kit how many db's does it produce.
Old Dec 26, 2007 | 10:03 PM
Utah Scions
Originally Posted by Djbombsquad
http://www.suicidedoors.com/showfullimage.php?type=products&image=4-PCTrainHornCompleteKit.jpg&title=4-PC%20Train%20Horn%20Complete%20Kit how many db's does it produce.
Lol!! Enough! My buddy has that exact kit underneath the bed of his s10. It's loud. Period. You can scare people from across the street with it. It's loud.
Old Dec 27, 2007 | 02:38 AM
I need at least 150+ DB if not 180DB or something.
Geedavell
Scion xD ICE & Interior
Sep 28, 2015 01:33 AM
BlingSlade
Sep 5, 2015 08:52 AM
ckylet11
Apr 16, 2015 10:36 PM
blh72
Jan 31, 2015 03:41 PM
Lads
Nov 28, 2004 06:01 AM
