OZnium.com LED dome light
8 Attachment(s)
2008-2011 xB LED Dome Light Product by: Oznium.com DIY By: Andrew A.K.A. The_Butcher Where to get this item: https://www.oznium.com/thin-led-domelight size: 5.0" x 1.5" Ease of installation: scale of 1-10. 1 being a trained monkey can do it, and 10 being seek professional help. I rate this a 2. Tools needed: 1. Precision standard screwdriver (eyeglass repair kit size) 2. Needle nose pliers PRE INSTALL TIPS:
STEP 1: Remove dome light cover
Attachment 62364 STEP 2: Remove OEM light bulb.
STEP 3: Install the adapter bulb.
Attachment 62365 STEP 4: Plug in LED light and install.
Attachment 62366
Attachment 62367 Attachment 62368 STEP 5: Tuck wires and recheck light.
Here's how I did it: Attachment 62369
STEP 6: Reinstall dome light cover.
That's it. ALL DONE!!! These LEDs will AMAZE you. The extra lighting is wonderful for finding things at night, or giving the little ones in the back seat the ability to see when buckling up. Whatever the use. This is a MUST for ALL vehicles. Attachment 62370 Attachment 62371 |
Nice, does it still fade on and off?
yes it does. That is is the electrical system not the bulb. :wink: Plus the fade is more prominent because of the type of light. :biggrin:
Looks like a nice easy upgrade. I still have issues with pictures of lights that are washed out with everything else black. Someone needs to make a tutorial on how take pics of lights in and on cars. May have to do some experimentation with that and post them.
I ordered the same light... It looks great I had the blue one installed from oznium.com but I got tired of the blue.
LED's aren't made to fade on and off like that though so if you keep it like that some are going to burn out quicker than they should. I did the same in my Tc and now the LED turns on but after a few seconds it dims out then just turns off when it should be on.
Originally Posted by Vulkinator
(Post 3817743)
If you are having an issue with your light I would suggest contacting the manufacturer and asking about their warranty policies. |
Remember that the fading/color changing underglow lights come with a controller module. That fade is most cases is actually a pulse width modulation of the light changing over the fade time. It is reducing current to the LED, but it also reduces it's ON time between OFF times. If you have an LED flashlight with different brightness levels try this: wave your hand in the beam. As your brightness decreases. you'll see a strobe effect. The lower the brightness, the more pronounced the strobe effect. LEDs are current driven, not voltage driven.
