push start install (now with DIY!!1!)
#61
Originally Posted by Maestro984
How do you set this up so that you push the button and the passenger seat ejects?
Anyone have a DIY for this?
#62
I know im bumping an OLD thread. but i have decided we goin in and doing this.
So idk how many ppl from this thread are still active. What other materials will i need? I heard i need a relay. and some other stuff. Still kinda foggy on what i need to do here. Can i get a better wiring pattern?
My starter button options
http://cgi.ebay.com/ebaymotors/PUSH-...item4aa09b636f
http://cgi.ebay.com/ebaymotors/Engin...item3a5fbcdb99
http://cgi.ebay.com/ebaymotors/HONDA...item35a938676d
http://cgi.ebay.com/ebaymotors/OEM-N...item4aa62a455f
Which ya'll like. i do like the blue theme. idk if its the right style though
#63
relay, wire connectors, and wire.
1st or 2nd on your list looks good.
Find the positive wire coming out of your ign switch when you turn the key all the way, thats the wire you want to tap into. find another wire in your fuse box area that turns on when the ign is on and make sure that it is thick enough, you will burn up your wire if it is not thick enough or it might not turn your car over because of the lack of power. hook up the other side of the relay like normal with your choice of switch.
i wanted to keep mine a little discrete so i went with the standard cig lighter. since i dont smoke or allow any one to do so in my car it was and easy choice.
i just out the key in and turn it to 'on' and make sure im in netural and hit the cig lighter and it starts right up.
its a very easy mod to do if you are comfortable with wiring and relays.
good luck
good luck
#64
Never tell me I never gave you anything lol...http://www.digitalguarddawg.com/handsfree-security.html
My dad uses these on his SandCar and Choppers they work great and you'll never have to use your keys.
#65
^^^ super ill. but at 400.... passsssssss im ok with using my key. and have it purley for look.
SA: what type wire do you suggest. and what type of relay? i used a relay for the grounding of my DVD player in the HU.
#67
FroZone, you sure you want to go this route?
You still have to put the key in the ignition in order to do this mod. It kind of defeats the purpose.
You'd be better off putting that $140 towards something like a dash trim kit, or those new interior chrome door handles I saw on ScionLife.
I like it a lot, but the fact you have to put your key in is totally not worth it for me.
cid_mcdp
01-05-2015 02:45 PM
TheTripleC
01-04-2015 06:46 PM
TheRedBox
31
12-02-2003 04:53 PM
