Shorted radio.. Now no power...
Old May 22, 2010 | 01:45 AM
NYXbScion's Avatar
Default Shorted radio.. Now no power...
Found the problem.... I fried the red power wire on the cars harness. Now I have to find out how to replace that wire.
Old May 22, 2010 | 11:19 AM
Aphex13's Avatar
I'm not sure about the xB, but there's another fuse box under the driver's side dash in the tC. It has most of the fuses for the interior stuff, ilumination, radio power, etc... It's worth a try. Good luck.
Old May 22, 2010 | 12:26 PM
XBinRochester's Avatar
Yes, the XB also has another fuse box under the driver side dash.
Old May 23, 2010 | 09:43 PM
buickid's Avatar
How did it short out? Were you cutting apart the factory radio harness? Are your wires uninsulated? Something doesn't sound right here.
Old Jun 4, 2010 | 06:25 AM
Slody4Futbol's Avatar
yeah, you shouldn't have to replace a wire, just a fuse. UNLESS, someone replaced the fuse for that wire with one that was of a higher rating, then didn't blow when the wire was shorted, which would then catch the wire on fire burning the insulation. If this is the case then just trace the wire back through the dash and try to find where it stops, if it goes too far then you will just need to run a new one.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
airmankevin1
Nov 17, 2015 05:44 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
excessads
Sep 15, 2015 05:28 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
