Switch cutout on 5 speed panel
So what is the switch cutout to the right of the manual shift lever intended to be used for?
Also, while I'm at it, how do the factory fog lights get switched? Where does that switch mount?
THat cutout is where the security system LED would go. and yes, the fogs are switched, left side of the dash by your knee you'll see a spot for three switches[/quote]
Originally Posted by NoLimitzInd
I moved my TPS switch over there and now have 3 rockers over on the left side of the wheel.
Was there enough wire to get it to reach over there? Also, I assume you had to take something apart, but was it just the console cover by the shifter or did you need to remove the lower dash assembly?
oj411
Dec 27, 2003 05:51 PM
