Passing through the fire wall
Im planning to wire up my 08 for a system. does anyone know the best place to go throught the firewall?? And is there an easy way to feed the wire through
the last time i did this was on my 89 nissan truck and there was alot more space in the engine bay to work with lol.
thanks
thanks
thanks
thanks
Believe it or not--Toyota only makes about four different firewalls. You should find a rubbery gommet where the wires pass through from the engine compartment to the interior. Carefully punch through there with a large phillips screwdriver. That is where I went to install my Randode engine compartment lights per the directions.
Ok guys just did it.
Found out the easiest way to do it.
Take a phillips screw driver, put a straw on the end of it, and work your way through the firewall.
Pull out the screwdriver and presto!! you got yourself a path to pass wires through
ScionLife Editor
Sep 24, 2015 10:50 PM
